Lift an E150 Van? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 29th, 2010, 03:06 PM   #1
mac66
Default Lift an E150 Van?
So I have my full size van that is no longer used as the family bus. I carry my ATV and/or dual sport motorcycle in it on occasion and occasionally use it for hunting, camping, fishing and backroading. I would like to make it more back road worthy but don't really need 4WD. I would however like to lift it up a bit and beef up the suspension.
Questions...
1. Can a E150 be lifted?
2. What larger tires and wheels might fit it as stock and or if lifted?
3. Does anyone around SE Mich do that kind of work?
4. Or am I crazy?
mac66 is offline   Reply With Quote
Old October 29th, 2010, 03:45 PM   #2
eagle-eye
what year is it? does it have i-beam and radius arm front suspension? if it does then a standard f150 2wd lift will suffice. may take a bit of fab work, but it would work. and youll clear 33's with 2.5" of lift.
eagle-eye is offline   Reply With Quote
Old October 29th, 2010, 04:19 PM   #3
mac66
It is a 99 with I-beams
Old October 29th, 2010, 04:24 PM   #4
0Toncaddy
Big Belly Customs
0Toncaddy's Avatar
if it has I beams it would not be that hard to swap in a TTB or straight axle and make it 4wd as well, a different trans and a t- case would be in order as well as driveshafts and shift linkages, considering ford actually offered a 4x4 van in the past parts could be obtained relatively easy and it would function normally as long as you didnt go crazy with the lift and tire combo...
0Toncaddy is offline   Reply With Quote
Old October 30th, 2010, 10:41 AM   #5
fsumotorhead
N8KVB
fsumotorhead's Avatar
the van beams are different than the trucks, and are +4" wider overall than a truck, so a truck lift will not work.
i would think a leveling kit from a truck might work, the puck things that go under the coil springs, or even the diesel van springs
Old October 30th, 2010, 10:42 AM   #6
fsumotorhead
N8KVB
ford never offered a 4x4 van, Quigley did the 4x4 conversions, and some dealers offered them, much like a conversion van
Old October 30th, 2010, 10:54 AM   #7
koochman450r
koochman450r's Avatar
just because they are wider it wouldnt work if he bought a lift that incorporated drop brackets? not new arms? idk i never checked it out but the lift on my 2wd ranger uses stock arms just drop bracktets for the radius arms and i beams.
you won this battle.
Old October 31st, 2010, 08:18 AM   #8
mac66
What about just using springs/shocks off a E250 or 350?
Old October 31st, 2010, 08:20 AM   #9
rob4407
rob4407's Avatar
Have you ever seen swamp loggers? They have a ford 4x4 van.
rob4407 is offline   Reply With Quote
Old October 31st, 2010, 09:51 AM   #10
fsumotorhead
N8KVB
http://www.quigley4x4.com/Products/F...ductsHome.aspx
Old October 31st, 2010, 10:22 AM   #11
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
seems like the best bet would be to contact the lift manufacturer and ask them. emails are free.
Old October 31st, 2010, 11:42 AM   #12
dodgeboy
redneck truck club
dodgeboy's Avatar
my dad has a 94 quigley van from n.c. everything in the conversion is from a f150. he has the parts list on everything to get replacement parts. they used a 79 dana 44 front axle. its kinda set up like a dodge front axle with a 4 link and same with the steering. but its all ford part numbers for brakes ball joints tie rods ect. if you want to do a 4x4 conversion i can scan the parts list and send you the info. it clears 32x11.50s with the aluminum running boards. if he takes them off it will go 33s hes wanting to go up to 35s. its fun to take out and it gets alot of looks!
a side note.... ive seen handicap e series vans with 3 inch body lifts to help clear with the side door ramps. might be a easy way to get a bigger tire also and might be a cheap way.
dodgeboy is offline   Reply With Quote
Old October 31st, 2010, 12:33 PM   #13
eagle-eye
but the brackets and such are basically the same in design. which i was getting at, not that the beams are exactly the same. im sure with a little bit of fab work a 2wd ford lift would work.
Old October 31st, 2010, 12:34 PM   #14
curt1656
Praise the lowered
curt1656's Avatar
http://www.ujointoffroad.com/
Old November 1st, 2010, 07:55 PM   #15
Never_Evil
There are going to people that will snarl when I suggest this, but hear me out. How about a body lift. This van will see occasional offroad use, just wants it higher to fit the bigger tires, however it won't do anything for the suspension to be "beefier"
Old November 2nd, 2010, 12:23 PM   #16
suepahfly
professional webwheeler
suepahfly's Avatar
Camburg has a suspension system for E-series vans, but it isn't exactly cheap.
suepahfly is offline   Reply With Quote
Page generated in 0.31153 seconds with 71 queries
