Gas Pedal Frozen 99TJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 6th, 2005, 12:33 AM   #1
Pongking23
CHOP'S Idol
Pongking23's Avatar
Send a message via AIM to Pongking23
Default Gas Pedal Frozen 99TJ
Lately i have had a problem with my 99TJ and the gas pedal, it freezes when it is cold out, i cant push it down at all, it takes about 20-30 minutes of warming the car up before i could push it down..............any way to lube the cable, or anything else, and has this happened to anyone else before.......
Pongking23 is offline   Reply With Quote
Old December 7th, 2005, 12:44 AM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
you can try to put wd40 on it but I don't think it will get in very far. Also I would triple check your grounds it could be a sign of a bad ground .
Old December 8th, 2005, 07:23 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
good point, but I think its a bad cable. I have seen lots of Burn't ones from what killer b mentioned. mostly they burned up parking brake cables and detent cables, the gas pedal cable is insulated better then most
Yetti
Old December 8th, 2005, 11:05 PM   #4
Pongking23
CHOP'S Idol
Pongking23's Avatar
i have no idea......in the mornings, when obviously it is freezing outside i cant push it down, and i warm the jeep up for like 15 minutes.....still does nothing, and about 3 minutes into my ride to school, the gas pedal finally starts to go down a little bit at a time...........................................
Old December 9th, 2005, 02:42 PM   #5
Yetti
Yetti's Avatar
I wonder if you have a bad throttle shaft, can you wiggle the shaft with the plate turned up off the idle position? it could be its wearing a grove in the throat of the bore and its digging in because its moving around on the shaft.
Yetti
Old December 9th, 2005, 03:04 PM   #6
Lothos
KD8GKB
Lothos's Avatar
I use Cable Lube with the adapter that i bought for my cycle. Best thing out there as its white lithium grease based. The adapter clamps on one fitting end and you blast into it forcing lube down the entire cable.
Here's an adapter: http://www.motoworldracing.com/Appli...Lube-Tool.html
Old December 9th, 2005, 03:05 PM   #7
Lothos
KD8GKB
Lothos's Avatar
The test is when it's doing that nonsense, pop the hood and see if you can open the throttle by hand without the cable.
Old December 9th, 2005, 10:31 PM   #8
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Sounds like water in the cable to me.
JcrOffroad
Zoom Zoom!
Old December 11th, 2005, 01:36 PM   #9
Pongking23
CHOP'S Idol
Pongking23's Avatar
thats what we think, but i dont know how to get it out....anyone have any suggestions
Page generated in 0.19471 seconds with 50 queries
