the '46 2A *82" of FUN* - Page 24 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 13th, 2013, 10:55 PM   #461
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Got the clutch figured out! Put it on the lift with Adam and my dad. The pilot bushing was hanging up on the input shaft like Adam thought. The clutch is a lot lighter than it used to be with the old trans and disc.
Drove around in fwd to test it worked well. Now to re-mount the battery and re-wire the winches.
ID:	109411   Click image for larger version
ID:	109412   Click image for larger version
Old August 18th, 2013, 08:47 PM   #462
jeepfreak81
81 inches of fun
Drove it today... it's going to be a more behaved little monster now.
I scared Adam doing doughnuts I think
Old August 19th, 2013, 09:10 PM   #463
jeepfreak81
81 inches of fun
Did some more work with Adam:
Mounted a usable rearview mirror with QD
Bolted the extra T-case mount up
Realigned the headers with heat and bending
mounted new military can mount (actual military and thicker steel)
Mounted battery - but need to get a different battery (Sealed and AGM) and better clamp.
Test fit my old YJ seats and debated making new mounts.
Old August 20th, 2013, 09:28 PM   #464
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
New cables made for front winch and moved the control box under the hood, Jacob dropped steel off for new seat mounts and trans cover. Will update when time allows
Old August 20th, 2013, 10:19 PM   #465
TJ/WILLYS
TJ/WILLYS's Avatar
I put Y/J seats in my CJ/2A and like them, but wish I would have Knotched the front of rear wheel tubs.
TJ/WILLYS is offline   Reply With Quote
Old August 21st, 2013, 10:08 AM   #466
jeepfreak81
81 inches of fun
Pretty sure that is going to be the best way to do it here too. I'd like to keep the front lip of the seat higher than the back as I like to sit back in the pocket a bit. I think it holds me in the seat better.
Old August 21st, 2013, 04:14 PM   #467
jeepfreak81
81 inches of fun
I also ordered The 12voltguy winch controller for the dash.
http://www.12voltguy.com/2.75-LARGE-BUTTONS.html
Old August 27th, 2013, 04:24 PM   #468
jeepfreak81
81 inches of fun
Old August 27th, 2013, 04:35 PM   #469
ZJeepMI
ZJeepMI's Avatar
This has to be one of the coolest Jeeps around, great job with the build.
ZJeepMI is offline   Reply With Quote
Old August 31st, 2013, 08:56 PM   #470
Jeepaholic
Jeepaholic's Avatar
Probably close to 200 miles on this since we got it running. Everything is working like a champ minus the many holes in the headers. Jacob picked up some manifolds to install a more protected exhaust system
Old September 1st, 2013, 03:49 AM   #471
It has turned out nice.
Old September 1st, 2013, 08:08 AM   #472
1TFROT
1TFROT's Avatar
looks pretty cool, nice job
1TFROT is offline   Reply With Quote
Old September 2nd, 2013, 11:34 PM   #473
TJ/WILLYS
TJ/WILLYS's Avatar
Look's really good. Hope mine turns out as good.
Old September 28th, 2013, 06:56 PM   #474
jeepfreak81
81 inches of fun
Damn exhaust systems have gotten expensive....
I wanted the other one that was in for work.... and I'm not talking about the POS Liberty.
Old November 2nd, 2013, 02:58 PM   #475
jeepfreak81
81 inches of fun
And new seats
Old January 1st, 2014, 10:54 PM   #476
jeepfreak81
81 inches of fun
I love that we made the front end electrical quick disconnect... it makes work on it so much easier.
Wired up the winch controller from 12v guy today.
Replaced the motor mounts tonight. One was shot, and I think is why the new exhaust came loose.
Prepped for some new lexan or glass for the windshield. Looking pretty soulless
I broke my front shaft in November, Adam fabbed up a new one right quick
Also started fixing the wobbly T98 shifter.
We shaved about 20-30 lbs off the top from random bolted on stuff.
I got it running smooth again, at least for now. It is running REALLY rich and I am having a hell of a time leaning it out the plugs keep fouling lately.
Need to fix the tire again - I just need new ones.
Need to put in glass
Need to fab a trans tunnel
Need to install the new seats.
Need to finish bolting on the top.
Need to take the exhaust back to the guy that did it for a repair.
Need to get at least the tach working.
Need to figure out some heat, or how to get the engine to warm up, the radiator works too well when its cold out - might just need cardboard for now.
I think that may be it for now.
Old January 4th, 2014, 06:29 PM   #477
jeepfreak81
81 inches of fun
Well I got to try the winches when I found out there was no shoulder to park on like I thought. I had not used the rear one yet.
Old January 4th, 2014, 10:30 PM   #478
suckyjunk
suckyjunk's Avatar
well did the ram reel in the Flattie for a kiss
or was there enough weight to pull it out from the ditch?
suckyjunk is offline   Reply With Quote
Old January 4th, 2014, 10:32 PM   #479
jeepfreak81
81 inches of fun
You can't see it in the pic, but the rear winch is spooled out and connected to the base of the telephone pole. It was the only anchor around.
It came out real easy, I was not expecting that with the trailer attached.
Old January 5th, 2014, 11:03 AM   #480
jeepfreak81
81 inches of fun
Snow duty... The rear winch and rack (about 200lbs total) add a nice ballast and made plowing much easier.
Page generated in 0.46411 seconds with 84 queries
