the '46 2A *82" of FUN* - Page 23 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 25th, 2013, 02:41 AM   #441
stinkpickle
bitter clinger
stinkpickle's Avatar
drooling on the underneath with skid plate idea. Detachable at the receiver would be even more practical though.
stinkpickle is offline   Reply With Quote
Old February 25th, 2013, 06:42 AM   #442
Renegade II
Coil springs are for pens
Renegade II's Avatar
Originally Posted by jeepfreak81 View Post
It is on a receiver mount. We discussed mounting it underneath with a skidplate to protect it though. I kind of like it on the receiver as I could easily swap it to my YJ when I get that going again.
The only thing I disliked about mine when it was on the receiver was bashing the mount coming off ledges or dragging it at the start of a steep hill.
Mount it underneath and get another one for the YJ. Stolen winches are cheap off Craigslist
Old February 25th, 2013, 10:41 AM   #443
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
I know I will probably end up changing it, but I want to at least try it.
I'd actually be surprised if it were stolen. It was an older guy that said he bought it for his Kubota, we did the deal at his house and he was obviously not hurting for money.
Old February 25th, 2013, 07:36 PM   #444
Renegade II
You could always put a receiver upright in the bed by the tailgate to store it. No tailgate and too much crap to work around so I passed on that idea.
Old February 25th, 2013, 08:42 PM   #445
jeepfreak81
81 inches of fun
I actually thought about just bolting it down in the bed since I have the diamond plate floor, I could tie it to the frame... but I figure I will want to re-install my backseat eventually.
Old April 9th, 2013, 02:43 PM   #446
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Got a few parts being dropped off here and there, also dinked around with the t case today swapping yokes and re shimming it. Hope to get this one done so I can finish the other non running jeep he owns
Old April 10th, 2013, 04:01 PM   #447
Renegade II
Tell him to just buy mine and be done with all this screwing around
Old April 10th, 2013, 06:30 PM   #448
jeepfreak81
81 inches of fun
I couldn't afford yours lol. It would get finished quicker if work would calm down. That and my trailer hunt was out of the way anyway.
Sent from my Nexus 7 using Tapatalk 2
Old April 21st, 2013, 12:23 PM   #449
TJ/WILLYS
TJ/WILLYS's Avatar
Any updates??
TJ/WILLYS is offline   Reply With Quote
Old April 21st, 2013, 12:39 PM   #450
Jeepaholic
Jeepaholic's Avatar
No sitting with two flat tires in my garage. Had to do a few other projects but hope to get some done this week
Old April 21st, 2013, 03:19 PM   #451
jeepfreak81
81 inches of fun
Originally Posted by TJ/WILLYS View Post
Any updates??
No my family and I have been sick, and Adam has been busy too.
Old April 21st, 2013, 05:31 PM   #452
Renegade II
$9500 and I'll throw in the trailer.
$39k and I'll throw in the H1 too
Old April 28th, 2013, 05:39 PM   #453
jeepfreak81
81 inches of fun
I shouldn't have bought my trailer... I should have just bought your jeep and trailer. You have to dangle it in front of me.... I wish I had a barn
On another note, we got the radiator mounts in, we just have do do some tweaking as the lower part of the radiator tank is damn close to the fan.
Old April 28th, 2013, 08:02 PM   #454
Renegade II
Getting there bit by bit! Looks good. Get it done by July for the dune run.
Old April 28th, 2013, 09:50 PM   #455
jeepfreak81
81 inches of fun
When is that? If nothing else we could take the H3, though I would NEVER get the sand out.
I don't think the TSL's would do well at the dunes, especially with the bead leaks.
Hopefully it will be done soon, I'd like to try out the new 4 speed at R&V. Work should be starting to slow down for a bit.
Old April 29th, 2013, 07:25 AM   #456
Renegade II
I've got extra sets of wider tires in the 32 range you can use at the dunes. Some 41.5's too if you're feeling really ambitious : sonicjay:
Old May 15th, 2013, 02:43 PM   #457
Jeepaholic
Jeepaholic's Avatar
Fixed the radiator and put on the lower hose, doof bought to big of the upper one. Steering column and shaft will be done here shortly waiting for paint to dry.
To finish;
Install OD
Make driveshafts (rear just needs welded)
Bend trucker shifter down
Finish cleaning up old wiring
Figure out battery and hook up
Old May 15th, 2013, 03:43 PM   #458
Jeepaholic
Jeepaholic's Avatar
Found a good spot for the 2nd winch
Old May 17th, 2013, 07:03 PM   #459
Jeepaholic
Jeepaholic's Avatar
OD was installed the other day
Wiring is pretty much done
New hose was brought over by Jacob and installed and filled the coolant
Old June 4th, 2013, 11:01 PM   #460
jeepfreak81
81 inches of fun
Got it all together aside from the battery relocation, and I have no clutch. Put it in gear and it will go like hell, but push in the clutch and it doesn't stop!
Adam and I have more work to do.
Page generated in 0.62004 seconds with 84 queries
