the '46 2A *82" of FUN* - Page 22 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 10th, 2013, 09:05 PM   #421
Renegade II
Coil springs are for pens
Renegade II's Avatar
Looks like next year we'll have to tighten up the trails a little bit to smash the shit outa that top too
Old February 10th, 2013, 10:18 PM   #422
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
I'd like to see Dan get down the tighter stuff My goal is to NOT smash this one. I may have to swap on the old one just for Snofari.
I can't wait to see how the rig changes for next year with more gear under it. Frankly, it probably won't affect it much as it'll still be an on/off switch for the fuel. I'd like to get new tires too, but I may just trailer it and keep these again. I can't decide what I want to put under it with the TSL's backordered for who knows how long. I wish I had not let my 15x8 chrome rims go either.
Looks like they are building me a ceramic clutch, hope it works ok, I know you can't slip them well, but after looking how burned the old one was I figured the upgrade might be worth it.
Old February 11th, 2013, 07:45 PM   #423
Renegade II
On that challenge Dan & I will find tighter trails Actually the 5 stays home and all of the pre runs are done in the Cherokee so we know he can fit. I never drive the trail til the day of the event!
I know where you can get a set of 16x35x16 Boggers already mounted on 5x5.5 :)
Ceramic isn't that bad, my 81 has one. Get a front locker so you don't have to play on/off switch with the skinny pedal. Those Warn OD's do not like on/off shock loads at all. Can't wait to see it back together!
Old February 12th, 2013, 11:59 AM   #424
jeepfreak81
81 inches of fun
How much stress is on the Warn OD when it is not engaged? Can it still blow if your not hammering on it specifically?
Old February 12th, 2013, 10:20 PM   #425
Renegade II
The main gear teeth like to go away if that crazy retainer nut / clip setup loosens up at all. I've been into three of them in my life and two were finger tight or backed up against that 4 point retainer clip. Use sleeve retainer and surface prep on that setup when you put it together.
The OD will not tolerate any abuse whatsoever without throwing up the planet gears. They are only a light duty OD for easy cruising, not a gear splitter for low range or tough terrain.
I got an OD from PP one time and couldn't make it fit with my PTO setup without frame chopping. Wish it would've worked, killed me to sell it.
Old February 13th, 2013, 07:18 PM   #426
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Think we will have to mod the upper bracket slightly but the column fits nice then fix the floor with the patch template I made using steel of coarse
The brake pedal return spring is not hooked up so the pedal is down a little
Old February 14th, 2013, 08:12 AM   #427
Renegade II
Hanging pedals & hydro clutch FTW
Old February 14th, 2013, 05:51 PM   #428
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Thru the floor pedals and hydro clutch FTM (For The Mojo)
I like that you kept a straight tube column...GM columns kill the flatty mojo as well.
Old February 14th, 2013, 06:04 PM   #429
Renegade II
Originally Posted by 4Bangler View Post
Thru the floor pedals and clutch for the wet feet, legs & crotch.
Fixed it for ya I hated my floor pedals with a passion!
Old February 14th, 2013, 10:04 PM   #430
jeepfreak81
81 inches of fun
I cannot stand the look of the GM columns in flatties. It looks terrible and out of place to me.
I like the through the floor pedals, the only trouble they have ever given me was when the clutch shaft was misaligned and I would lose the linkage. I have never had wet feet because I try not to play in deep water, I am too scared to lose an engine or something, and no matter what I do I can't seem to get my oil pan to seal up well.
I won't be putting in a hydro clutch, I can't see the need to, and it is just adding more complication that can fail - just like I did with the fan. If my clutch cable breaks on this, I could even use a piece of rope if I needed to and get back on the trail.
Old February 17th, 2013, 08:45 PM   #431
jeepfreak81
81 inches of fun
I love Craigslist.. with a receiver mount, cheap.
Old February 18th, 2013, 07:55 PM   #432
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Advance adapters clutch chain setup is pretty slick....
Old February 19th, 2013, 08:59 AM   #433
Renegade II
Wilwood hydro master/slave setup with braided AN line. Easy to install and route out of harms way. Beats cable or chain hands down.
Old February 19th, 2013, 02:19 PM   #434
jeepfreak81
81 inches of fun
Guess I don't see what is so bad about the current setup? My clutch is no stiffer than my old 85 S10 with a Hydro clutch....
Old February 19th, 2013, 09:07 PM   #435
Renegade II
Dirt, mud, rust, sand etc.. gets in the cable, pivots and wears out the bushings/cable/sheath. The trail ride stuff I do always seemed to kill the cables every couple years. Never a problem since hydro and more room for PTO shafts or exhaust inside of the frame. Stiffness can be smoothed out by using different size MC / slave bore sizes. Mine is smooth and light.
Old February 22nd, 2013, 07:54 PM   #436
jeepfreak81
81 inches of fun
Clutch is done...
Old February 23rd, 2013, 10:05 PM   #437
jeepfreak81
81 inches of fun
Pics of my shaft : Tonka:
ID:	102356   Click image for larger version
ID:	102357   Click image for larger version
Old February 24th, 2013, 06:46 PM   #438
jeepfreak81
81 inches of fun
Old February 24th, 2013, 06:53 PM   #439
stinkpickle
bitter clinger
stinkpickle's Avatar
Is this winch plugged into a receiver or directly bolted on?
stinkpickle is offline   Reply With Quote
Old February 24th, 2013, 10:33 PM   #440
jeepfreak81
81 inches of fun
It is on a receiver mount. We discussed mounting it underneath with a skidplate to protect it though. I kind of like it on the receiver as I could easily swap it to my YJ when I get that going again.
Page generated in 0.49570 seconds with 84 queries
