the '46 2A *82" of FUN* - Page 21 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 2nd, 2013, 04:38 PM   #401
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
I love summit racing!
Ordered at 3pm on a Friday, I get it 5:30pm on Saturday for no extra charge!
ID:	101473   Click image for larger version
Old February 2nd, 2013, 04:46 PM   #402
Renegade II
Coil springs are for pens
Renegade II's Avatar
10.5" pressure plate?
Hope you ordered a real fan too!
Old February 2nd, 2013, 04:58 PM   #403
jeepfreak81
81 inches of fun
Working on finding a fan for it... I am not super keen on flex fans, though the ones I have used have proven themselves to be better than that electric. I just always cut myself on them.
I believe it is a 10.5" pressure plate, as I believe that disc was a 9.5"
Old February 2nd, 2013, 05:09 PM   #404
Renegade II
There are some 10.5" early 70's Ford cars with the same count & size splines as the Jeep disc. You just need to mill (or grind) about 1/8" off the disc hub for clearance. That's how mine is set up.
SOLID steel blade, no 'flex into your radiator' fan!
Old February 2nd, 2013, 05:29 PM   #405
jeepfreak81
81 inches of fun
Looking at this fan right now.
http://www.summitracing.com/parts/fl...s/?prefilter=1
I need to find a clutch plate cross reference I guess to see which ones. I never have had to deal with custom stuff like this yet
Old February 2nd, 2013, 05:37 PM   #406
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
He needs a 15/16" 10 spline disc not the 1 1/8" 10 spline like the ford/jeep uses
Old February 2nd, 2013, 05:50 PM   #407
Renegade II
Looks like that'll work. I'm running a factory 4 blade, looks to be 1/8" steel. And it doesn't eat my radiator when I do this...
I can't find my clutch spec book around here right now. Wife probably threw it away
Old February 2nd, 2013, 07:37 PM   #408
Jeepaholic
Jeepaholic's Avatar
Found a Scout 4 cyl clutch with the correct input spline and 10" diameter vs the V6 10.25" and the 4 cyl willys is 9"
Old February 2nd, 2013, 08:36 PM   #409
jeepfreak81
81 inches of fun
I have not been to the dunes in years
Old February 3rd, 2013, 08:58 AM   #410
4Bangler
Jackstand Wheeler
4Bangler's Avatar
There are a few companies out there that will build you a custom clutch disk for not much more than a good quality replacement clutch....when I swapped the SM420 into my 2.5L YJ I had just replaced the stock clutch with a heavy duty LUC clutch and I think it was Clutch Dynamics that made me a custom heavy-duty disk with a Chevy hub to fit my SM420....as I recall they had tons of options.
Old February 3rd, 2013, 09:27 PM   #411
jeepfreak81
81 inches of fun
I will check into them...
Test fitting
Old February 4th, 2013, 07:59 AM   #412
Renegade II
Hey, your radiator is in there sideways
Old February 4th, 2013, 09:03 PM   #413
jeepfreak81
81 inches of fun
A lot of the early 5 guys were running Fiero cross flows, I figure this should be a little better
New steering shaft on the way, fan and spacer on the way, and hope to order a column next paycheck.
This thing has really taken care of me, this is the first real money put into it. Hopefully I can get a clutch disk, I found the throwout bearing today. Looking more like a custom clutch disk will be in order, I have an email into the company 4bangler mentioned.
Old February 5th, 2013, 01:11 PM   #414
jeepfreak81
81 inches of fun
Well, My rear driveshaft was >< that close to breaking. Adam noticed it is twisted like a pretzel, just not broken when he was measuring it to see if I would need to shorten it.
Clutch Dynamics wants to look at my pressure plate and stuff, they think they can make me the clutch disk I need for about $100. They seem VERY knowledgeable and are genuinely nice people on the phone. They asked that I bring my old parts over, and what I have and they can get me something that will work.
Trans mocked into place with all the levers...
Old February 5th, 2013, 04:16 PM   #415
Renegade II
While you're at it get some locking diffs in that rig so you won't need to use that skinny pedal so much.
Old February 5th, 2013, 04:46 PM   #416
jeepfreak81
81 inches of fun
It is locked in the rear I probably don't HAVE to use it the way I do, but it's so fun to treat it like an on/off switch in this rig
Old February 6th, 2013, 08:41 PM   #417
jeepfreak81
81 inches of fun
More showed up today:
Column should be here Friday, and Clutch Dynamics has my parts, should have a quote to me tomorrow.
Old February 10th, 2013, 01:04 PM   #418
jeepfreak81
81 inches of fun
I picked this up yesterday from TJ/Willys on here. Great guy, really took care of me when I had a trailer break down.
I'm going to try not to bang this one up. I am still confused how on every one of these tops I have looked at the door latches are broken and mangled beyond operating.
Old February 10th, 2013, 01:05 PM   #419
jeepfreak81
81 inches of fun
Old February 10th, 2013, 05:34 PM   #420
dreezy
Haggard Fab
dreezy's Avatar
I like that color scheme.
Page generated in 0.41965 seconds with 84 queries
