the '46 2A *82" of FUN* - Page 16 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 28th, 2009, 12:45 PM   #301
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
What? No, "that looks hillbilly" comments? Man you guys are slacking
You get U bolts yet?
Old October 28th, 2009, 12:54 PM   #302
Pokerob
hug life
Pokerob's Avatar
best plow jeep ever!
Old October 28th, 2009, 01:05 PM   #303
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Maybe not, the jeep is too damn light I am going to bet. Good excuse for lockers maybe. I need to get the cab mounted up too
Trade for plow tug? I just hope it works well, the 6' plow I have is fawking heavy. I'll find out probably next weekend when I get all the parts together and maybe hook the plow itself up for the first time.
my wife would kill me
Old October 28th, 2009, 01:10 PM   #304
Pokerob
hug life
Pokerob's Avatar
just plow everyday and it will work fine
you can buy the tug if you want and covert that. i think i might sell it next spring/summer or change it to 31-33's.
Old October 28th, 2009, 08:43 PM   #305
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
my 2a had a 6' plow and it worked good.
if you are plowing with it I am probably going to be getting rid of the vinyl half top/doors i have for a 2a if you are interested in being covered.
Old October 28th, 2009, 09:35 PM   #306
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
no way...my dad used a cj2 for a plow jeep for 20+ yrs at our cabin in drummond island...and if it could work there it could work down here no problem
Old October 29th, 2009, 07:10 AM   #307
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Just don't plan on angling the plow much in deep snow, tends to just angle the Jeep instead. I've seen a Pinto 4cyl powered CJ-2A push 24" heavy wet snow until it was coming over the top of the plow, and that was on stock-ish tires with chains and open diffs. Make sure to brace your lower carriage WAY back on the frame, like at the T-case, makes a HUGE difference.
Old October 29th, 2009, 09:41 AM   #308
jeepfreak81
81 inches of fun
Definitely interested, any pictures? My tub is so tweaked the hard top I already have doesn't fit right
It should be ok, we don't get more then about a foot around here. The only reason I am doing it is because I plow the large driveway by my house, and the neighbors driveway. My tractor just wasn't quite up to the task once it got over 6-8" it was too dang light.
We may have to add in some bracing bars later. I want to see how this simple setup works first for a few passes, the bracing it will have isn't done yet either.
Old November 7th, 2009, 07:29 PM   #309
jeepfreak81
81 inches of fun
Well It would be done if some genius hadn't spec'ed this out with 1/4" bleeder screws. I broke them off, no one stocks them, and because it is an oddball axle they are $30 each instead of $8 each.
Plow mount is done, and axle is installed otherwise. Also installed a new pinion seal and rear t-case output seal.
Jeep is now "Miller Locked" in the rear as well. I hope I don't regret it.
I also have some painting to do... one of these days I will tear the whole damn thing apart and paint from the chassis up. Maybe wwhen I have my own garage.
Old November 7th, 2009, 07:45 PM   #310
cj65
cj65's Avatar
Just wanted to say i like your cj2a. I bought your old axles from adam . Just bought a set of lockers off c/l and going to install them soon. You will be happy plowing with your 2a . My cj 5 was aplow jeep before my family ended up with it in 89 . Good luck with the rest of your bulid
Old November 8th, 2009, 09:05 AM   #311
jeepfreak81
81 inches of fun
I think you will be happy with them, they gave me a few years of trouble free service.
I think it will be fine too for the amount of snow we get. I think this mount is better built then what was originally with the plow as well. Thanks for the props
Old November 8th, 2009, 09:12 AM   #312
Pokerob
hug life
Pokerob's Avatar
I welded my rear NT d44 (72' mail jeep axle). I have run 35's and 37's on the street with no problems. I have no experience in winter conditions with it but in the summer months it was fine on the highway and around corners. I think you will like it.
Old November 8th, 2009, 10:59 PM   #313
suckyjunk
suckyjunk's Avatar
He may be referring it to be a bit squirrelly in snow and ice conditions. I know my '91 Islander with a Trac-loc on Q-78 Buckshot Mudders, I could not negotiate a turn in 1" of snow without being locked in to 4WD in order to turn at a simple intersection.
suckyjunk is offline   Reply With Quote
Old November 9th, 2009, 08:58 AM   #314
stinkpickle
bitter clinger
stinkpickle's Avatar
hmm. words to ponder, was looking at welding the rear end on my 2a. You give me things to think about.
stinkpickle is offline   Reply With Quote
Old November 9th, 2009, 09:10 AM   #315
jeepfreak81
81 inches of fun
Originally Posted by stinkpickle View Post
[/COLOR]
What axle do you have, I don't know that I would recommend it with a stock 2pc rear.
Old November 9th, 2009, 09:13 AM   #316
stinkpickle
bitter clinger
Im going to run an amc 20 with 1 pc rear 31 " tires
Old November 10th, 2009, 07:05 AM   #317
jeepfreak81
81 inches of fun
Are you swapping out the D18? An AMC 20 is centered.
Old November 10th, 2009, 08:47 AM   #318
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
maybe he got a quadratrac 20 out of a 7?
Old November 10th, 2009, 08:51 AM   #319
jeepfreak81
81 inches of fun
I thought of that, but wow I have not seen one in years. The last one I saw was in a field, and I couldn't get the person to sell the jeep. They thought it was still worth thousands even though the frame was rotted in half, and the tub was falling off. I wanted it for the little ebay items IE laredo clock, and axles.
Possible I guess, I just figured between the gear ratios they came with and rarity, it was unlikely.
Old November 10th, 2009, 09:28 AM   #320
Renegade II
Coil springs are for pens
Renegade II's Avatar
.....Jeep is now "Miller Locked" in the rear as well. I hope I don't regret it......
They are ok on dry roads, but road driving an early CJ with a rear spool or full locking rear diff on snow/ice covered roads is not fun, especially roads with patchy ice. I think we got up to 30 MPH on our ride back to the hotel from the trail at last years SnoFari.......and that was scary. We would hit a patch of ice and do a lane change without moving the steering wheel, just ask Danimal what it was like It was bad enough that the 8 will now be getting an ARB in the rear instead of a Detroit.
Page generated in 0.66866 seconds with 84 queries
