the '46 2A *82" of FUN* - Page 12 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 22nd, 2008, 09:40 AM   #221
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Well I don't know how your supposed to install the glass seals and inner to outer seal, but I fucked them both up. The aftermarket windshield frames 'grooves' for the glass are much to thin to accept glass + seal, so for now I have plexi in there again.
The inner to outer seal was shitty quality, the 'T' part of the seal did not fit well into the seal groove and when trying to slide it down the frame it tore It didn't help that the seal seemed to be a little short, and I was having to try to stretch it a little.
I'll get pics when I get home, I might be able to salvage it with superglue if I can get the seal into the damn inner frame. I am half temped to just save up for a really good condition original frame. The inner and outter just absolutely did not want to slide back together either despite grease, and nothing had changed from dry assembly on the garage floor. But now I have a small dent in the drivers side of the inner frame too.
Old September 22nd, 2008, 10:00 AM   #222
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
I knew the glass would be too thick to accommodate the original style rubber seal, infact the glass shop said it most likely would not work. the glass fabricator said he could custom cut the glass to fit the frame and install it with newer but still serviceable methods. to seal the glass to the frame he used a light black silicone that looks like rubber.
as for the outer rubber seal. by far this could be the most difficult thing I have ever done. I used tons of soap for lubrication and rounded off the end of a carpenters shim to push it in the frame. still it tore in the corners and I glued it back together. it fit in there good but imo the seal is made of way too brittle rubber.
if the super glue doesn't work get some locktite 2 part plastic glue as that glue it awesome for plastic, rubber, etc.
Old September 25th, 2008, 05:36 PM   #223
jeepfreak81
81 inches of fun
Together minus the seal using plexi again for now.... The plexi is dirty, not scratched.
I will dick with it when I get more time I guess...
Old October 1st, 2008, 03:10 PM   #224
Dalton
Dalton's Avatar
I love this thing and will have one like it one day......
Dalton is offline   Reply With Quote
Old October 3rd, 2008, 11:19 AM   #225
jeepfreak81
81 inches of fun
Going to pull the grill and front clip off this weekend... Apparently nothing is really holding it on other then the fender to tub bolts because I broke the mount
Looks good with the trailer though, need some J bars for the Kayaks... Why are they so expensive?
Old December 11th, 2008, 08:31 PM   #226
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
updates slacker
Old December 12th, 2008, 09:54 AM   #227
jeepfreak81
81 inches of fun
Originally Posted by 99grandtj View Post
updates slacker
I haven't done anything
Unless your talking about the acquisition of this....
And hopefully I will have a winch strong enough to hang the thing from a tree soon (I hope it is cheap)
Old December 12th, 2008, 09:58 AM   #228
Jeepaholic
Jeepaholic's Avatar
Someone came over and fixed the grill problem?
Old December 12th, 2008, 10:05 AM   #229
jeepfreak81
81 inches of fun
I have no pictures of that yet
It is freaking solid now though
Want to come fix my tractor now, MTD/Cub Cadet needs to learn to weld instead of use bolts on very important pieces
Old December 12th, 2008, 10:05 AM   #230
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
I hope you didn't use a flash for your picture- I would hate to wake that cute little guy up.
Old December 12th, 2008, 10:06 AM   #231
Renegade II
Coil springs are for pens
Renegade II's Avatar
Sweet, I was thinking about switching over to front drums also
I have spare shafts & maybe a drum for that if you need any parts
Old December 12th, 2008, 10:08 AM   #232
jeepfreak81
81 inches of fun
It is bigger drums then I have... but turning radius is what I was going for
FINALLY! I may end up putting the 10" drums on this axle though so I don't have to buy new wheels right away. Money has been tight
Should have seen the wifes reaction when she saw that in the back of her Focus
Old December 12th, 2008, 10:28 AM   #233
Jeepaholic
Jeepaholic's Avatar
I will trade you a set of wheels for the 27 how about that?
Old December 12th, 2008, 01:14 PM   #234
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
narrow track d30. I have a mostly complete nt disc brake d30 I don't think i am going to use.
Old December 12th, 2008, 02:08 PM   #235
jeepfreak81
81 inches of fun
More importantly it is a 3.73 NT D30. Adam and I (mostly Adam) kept tracking down NT D30's that were supposedly 3.73 so I wouldn't have to regear, he would get there and discover they were actually 3.54.
This one is a real 3.73 axle so I can bolt it right in
Old December 12th, 2008, 09:17 PM   #236
get his, too, and put the disc knuckles onto it. Thats what I did with mine (1975 with, yep, 3.73s). The 72-75s are the 3.73s (or 4.27s), the laters are 3.55s, people seem to confuse them.
God flatties look awesome on 34x.9.5s tsl's.
Old December 13th, 2008, 08:24 AM   #237
Jeepaholic
Jeepaholic's Avatar
We are worried with the single camber master that the disc would be to much for it. There were mixed results on Earlycj5 with the results.
Old December 13th, 2008, 08:51 AM   #238
Cooter
Cooter's Avatar
Should have contacted me- I have a few.
Old December 14th, 2008, 10:26 PM   #239
jeepfreak81
81 inches of fun
I was just in Gurnee too.. problem is it wouldn't have fit in the car with both dogs and our weekend gear... Sandals lives about 2 miles from my wife's parents - and I STILL haven't had a chance to have a beer with him.
I should upgrade to a dual chamber master... but need the YJ done first.
Old December 15th, 2008, 09:56 AM   #240
jeepfreak81
81 inches of fun
Adam came over and bent these up and welded them on, I have a little grinding to do on the welds, but hell the whole jeep isn't pretty. These reinforce the grill support and help to hold it in place.
Page generated in 0.47524 seconds with 84 queries
