6.0 powerstroke problem...shocking huh! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 26th, 2010, 10:41 PM   #1
blittle913
blittle913's Avatar
Default 6.0 powerstroke problem...shocking huh!
My truck will start right up and run fine for about 5 min then it just shuts rights down. Iv replaced fuel pump and filters and the cam shaft positioning sensor. Still does the same thing. Its not throwing any codes either. Its an 04 f350. Please help me!
blittle913 is offline   Reply With Quote
Old October 29th, 2010, 05:17 AM   #2
dzltech
If you haven't already done it then check your air filter. I've seen very dirty air filters do this...twice recently.
dzltech is offline   Reply With Quote
Old November 2nd, 2010, 07:58 AM   #3
Quiefinator
go'til itsounds expensive
Are you just replacing shit without diagnosis or have you replaced them in the past?
I believe 6.0 have a high oil pressure sensor that will go bad and cause this. Its a safety feature that will shut down the motor if a certain oil pressure is not achieved. Don't quote me, but i remember hearing
something like that. Good luck
Old November 19th, 2010, 06:15 AM   #4
88fordman
88fordman's Avatar
Did you fix it?
If not, pull the upper fuel filter cap and see if the cup is empty when it dies. I know you already replaced the pump and filters, but it would be nice to know if its getting fuel. Also a X2 on the air filter.
88fordman is offline   Reply With Quote
Old November 20th, 2010, 11:23 AM   #5
mprmn08
mprmn08's Avatar
are the 6.0's the same type of injection as the 7.3? if so theres a little oring i believe under the intake (if i remember right) that sends oil to the injection system to open the injectors. my buddy had it happen on his 7.3 and it wasnt getting enough oil pressure to open the injectors. he thought it was bad injection pump but it ended up being a $.30 oring. just a thought.
Page generated in 0.21751 seconds with 38 queries
