Starting another one... Currently Functional. - Page 26 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 27th, 2013, 11:04 AM   #501
1 ton tj on 40's
1 ton tj on 40's's Avatar
have been looking for part out an the parts sec
Old June 27th, 2013, 03:22 PM   #502
Strangler
Strangler's Avatar
I have a mullet run to win.
Old June 28th, 2013, 10:55 AM   #503
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Adda boy
Old June 28th, 2013, 10:58 AM   #504
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Epic
H.o.r.e
Old October 8th, 2013, 10:31 PM   #505
Strangler
Strangler's Avatar
[Placesaver for pics of my TJ with the Mustache Run trophy on the hood]
Old October 9th, 2013, 05:47 AM   #506
Who are you borrowing it from?
Old October 9th, 2013, 08:36 AM   #507
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by Strangler View Post
Threw some more caster at it (to 7 from 4), and switched to a shorter pitman arm last night. I'll build a longer draglink tonight and take it for another drive.
Old post, but I just saw it. Why'd you have to swap to a shorter pitman arm? Seems like almost everybody running a D60 in a TJ needs a longer pitman arm than stock(Astro, Waggy, etc). I just got a Waggy arm for mine but would curious to know what you ended up using and why.
Old October 9th, 2013, 08:43 AM   #508
Klumpper
Fuck Cancer!
SO this is why you haven't helped find tires for my truck!
Klumpper is offline   Reply With Quote
Old October 9th, 2013, 09:19 AM   #509
Strangler
Strangler's Avatar
Originally Posted by chevotass View Post
to answer your text message questions:
I bought the $24 a foot rubber submersable hose. i got a small pipe cutter and cut the fuel inlet tube up higher near the top of the cell. with the 1ft flexable line i could set the pump in the tank mounted to the threaded rod. install hose from pump to stock fuel outlet in top of tank. then set steel rci filler neck on and send the 3/8 in the hole i had already in rci top. tighten lid and tighten bolt on 3/8 rod. all done.
as for wires i drilled and installed in chord grip connector. ill take a picture for you. its an electrical connector i use at work alot. cost me $5.86 at the supply house. but basically it bolts to the rci lid. then it has a rubber bushing with a 1/4" hole that i fed the 2 #14 wires threw. Then it has an outer threaded hub that tightens the rubber bushing and seals around the wires. i chose the rci filler to mount everything because it was removable and i could keep from any debris falling into cell when drilling it out.
Nick, when I took your advice a year ago I mounted my pump like you suggested. The pump was 3/8 outlet and the siphon tube was 1/2, so I used a double-nipple to splice the two sizes together. I was unsure if my blue Goodyear hose could be submersed in fuel so I threw a chunk of it in a salsa jar with some gas which has since proven to deteriorate. I bought some submersible hose but it only came in 3/8. What did you use to step up to your siphon tube? I'm gonna hit Grainger at lunch to see if they have a 1/2" compression fitting that could be used, but what did you do?
Old October 9th, 2013, 09:21 AM   #510
Strangler
Strangler's Avatar
You bring the Mog on rollers and I will let you win.
Old October 9th, 2013, 09:24 AM   #511
Strangler
Strangler's Avatar
I'll check when I get home, but I think that was a typo. I believe I ended up using a waggy arm which was LONGER than the one I started with. Trade me tires.
Old October 9th, 2013, 10:30 AM   #512
bbaXJ
Yooper In Training
bbaXJ's Avatar
Trade me tires.
Convince me.
I'm concerned with streetability and not breaking stuff, but downsizing just doesn't seem right.....I mean there's gotta be a reason you want mine so bad
Old October 9th, 2013, 01:00 PM   #513
Strangler
Strangler's Avatar
Because I built this bitch on 40s and that's what looks right on it. You still have a chance....
Pm me what it would take to make it happen.
Old October 9th, 2013, 01:03 PM   #514
bigbchevy
missmrgreenagain
bigbchevy's Avatar
H.o.r.e
Old October 9th, 2013, 01:19 PM   #515
firehawk
Live Action!
firehawk's Avatar
I have a set of 39.5 Iroks.
Old October 9th, 2013, 01:53 PM   #516
bbaXJ
Yooper In Training
bbaXJ's Avatar
I have no idea what it'd take. Just trade me Jeeps and we'll call it good
Old October 9th, 2013, 02:33 PM   #517
chevotass
chevotass's Avatar
I was a man about it. and made the 3/8 hose fit on the 1/2" tube.
chevotass is online now   Reply With Quote
Old October 9th, 2013, 02:44 PM   #518
At this rate Strangler will never be done. sheesh.....
Old October 9th, 2013, 03:57 PM   #519
1 ton tj on 40's
does it even have a tranz an shifter yet before we start talking tire's
Old October 9th, 2013, 06:19 PM   #520
Strangler
Strangler's Avatar
Originally Posted by Chevotass View Post
I put the 3/8 on the 1/2"....
Really?
Page generated in 0.49623 seconds with 84 queries
