Starting another one... Currently Functional. - Page 23 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 23rd, 2013, 01:59 PM   #441
Tom
Because racecar
Tom's Avatar
If Bud Light drives it again, say goodbye to the rear band, rear servo, or case of the th400 he is putting in it
Old March 23rd, 2013, 03:39 PM   #442
kickstand
circling the drain
kickstand's Avatar
Originally Posted by Tranny Tom View Post
If Bud Light drives it again, say good buy to the rear band, rear servo, or case of the th400 he is putting in it
Old March 23rd, 2013, 07:32 PM   #443
Tom
Because racecar
Tom's Avatar
Stupid auto word.
Old March 23rd, 2013, 09:27 PM   #444
Strangler
Strangler's Avatar
Someone forgot to unpin the throttle from the floor before they put it in reverse.
Unpossible. I had a worn-out B&M shifter.... it took me minutes to switch from F to R.
Old March 23rd, 2013, 09:28 PM   #445
Strangler
Strangler's Avatar
Originally Posted by bigbchevy View Post
Budlight did that tom
Stupid beer.
Old March 23rd, 2013, 11:12 PM   #446
Tom
Because racecar
Tom's Avatar
Reverse to drive then.
Old March 23rd, 2013, 11:43 PM   #447
Strangler
Strangler's Avatar
mere speculation.
(you keep your mouth shut, Elusive)
Old March 24th, 2013, 12:31 PM   #448
1 ton tj on 40's
1 ton tj on 40's's Avatar
sounds like time for the part out
Old March 24th, 2013, 03:13 PM   #449
Strangler
Strangler's Avatar
Dont dare me.
Old March 26th, 2013, 05:06 PM   #450
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by Strangler View Post
Stupid beer.
You take that back!! Take it back right now!!
Old March 26th, 2013, 06:58 PM   #451
Strangler
Strangler's Avatar
I can never stay mad at beer for long. I usually forgive it by 9 or 10 am.
I forgot to mention that I put a Detroit in the rear a me while its been down. While doing so I think I discovered what my mysterious "rear axle noise" was, which has been there since day one.
Old March 26th, 2013, 07:00 PM   #452
kickstand
circling the drain
kickstand's Avatar
Stupid auto word.
I didn't even catch that, I was just laughing at what you said
We really are brothers from another mother
Old March 27th, 2013, 09:30 PM   #453
chevotass
chevotass's Avatar
does it shift yet
Old March 27th, 2013, 11:07 PM   #454
1 ton tj on 40's
Originally Posted by chevotass View Post
does it shift yet
come on now you know better
Old March 27th, 2013, 11:29 PM   #455
Strangler
Strangler's Avatar
New mainshaft showed up today, trans can now be assembled. Shifter is back-ordered =(
Oh, and a baby LS is scheduled to make an appearance......
Old March 27th, 2013, 11:42 PM   #456
1 ton tj on 40's
what a case of 24oz whats the plans for the old motor?
Old March 28th, 2013, 10:26 AM   #457
Strangler
Strangler's Avatar
Not sure yet. I'm happy with what I have but I want to re-do my front shock hoops which are tied into my engine mounts so if I'm ever going to go LS now is the time. I bought a 4.8 that I may run just to get wiring and accessories all sorted out and if I like it maybe ill build something hotter.
Then again, mine runs just fine, so I don't know.
Old March 28th, 2013, 10:35 AM   #458
bigbchevy
missmrgreenagain
bigbchevy's Avatar
What was wrong with the 14 bolt?
H.o.r.e
Old March 28th, 2013, 10:55 AM   #459
Strangler
Strangler's Avatar
I won't really know until I drive it again, but here's where I'm at:
For years I ran the same set if welded spiders is the same carrier in the same axle and all was well. When I built the jeep I used the same spiders and carrier but installed them in a different housing. Since day one, I have had a rattle/vibe/noise coming from the rear when I coast at speed. I have a nice pattern, and am confident that the pinion is properly set. The straddle bearing was bad and that fix cured a lot of the noise, but it's still there.
Upon disassembly to install the Detroit, I noticed that the inside of the carrier was chewed up from the spiders, more specifically the weld in the spiders. I ran a bead in between the teeth but ran the bead a bit long, essentially increasing the outside diameter of the spiders in those localized areas. Those high-spots of weld appear to have bees contacting the carrier. What confuses me is that this is welded..... so the spiders should never be spinning inside the carrier, right? I'm confused and my thumb is tired.
Old March 28th, 2013, 11:19 AM   #460
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Weird
H.o.r.e
Page generated in 0.39098 seconds with 84 queries
