Starting another one... Currently Functional. - Page 19 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 18th, 2012, 09:28 PM   #361
Strangler
Strangler's Avatar
Great.
On the way home from work I bought a Ram master cylinder, ripped my junk apart and didn't have a bolt to use to extend the pushrod, so the brakes are apart.
I swapped the stock power steering pump for the new PSC stuff, mounted the res, etc but I am missing a chunk of hose so the P/S system is all apart.
I swapped the welded spiders back into the 14b, but ran out of rtv just after installing the axle shafts and will need some more for the diff cover to button it up.
So, as noted above, I could have used my Jeep today. Instead I took it apart again. Stupid Jeep.
Old July 18th, 2012, 09:36 PM   #362
1 ton tj on 40's
1 ton tj on 40's's Avatar
but you love her
Old July 19th, 2012, 09:36 AM   #363
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by Strangler View Post
Great.
This is why I just save myself the trouble and never finish putting my rigs together in the first place
Old November 26th, 2012, 03:12 PM   #364
Strangler
Strangler's Avatar
Serious fuel delivery issues. I've burned up two Holley blue pumps now, and I'm not sure why. The pump is mounted to my frame rail, under the driver seat.... the tank is an RCI mounted behind the rear seat. Tank outlet is on the top of the tank. Pump is wired to and fired my the GM TBI computer (FP relay). Return line is the same -6 that the feed is. I've melted the brush assemblies in both of these pumps (which were both previously used without issue) .
Should I:
1) Install another one and cross my fingers
2) Install a sump in the bottom of my tank, thinking the siphon tube to the top is overworking my pump
3) Cut the tank open and mount a GM TBI in-tank pump in there (hose clamped to the siphon tube?)
4) Install a different external pump
5) Part this bitch out
Old November 26th, 2012, 03:15 PM   #365
bigbchevy
missmrgreenagain
bigbchevy's Avatar
5=buy bdmt
H.o.r.e
Old November 26th, 2012, 03:23 PM   #366
Strangler
Strangler's Avatar
I drive buy on trash nights, waiting to see it at the road.
Old November 26th, 2012, 03:28 PM   #367
kickstand
circling the drain
kickstand's Avatar
I keep doing the same
Old November 26th, 2012, 03:33 PM   #368
tom77cj5
tom77cj5's Avatar
Should I:
i had three bungs welded in the bottom of my fuel cell to avoid fuel issues like your having, that's my vote but I'm also using a high pressure pump
Old November 26th, 2012, 04:19 PM   #369
tweak
Are we there yet?
tweak's Avatar
Should I:
A fuel pump will work better in a "push" scenario then in a "pull". Putting a TBI in-tank pump would cure you of this issue.
Old November 26th, 2012, 04:22 PM   #370
Strangler
Strangler's Avatar
We have the same cells, wanna trade?
Old November 26th, 2012, 04:23 PM   #371
Strangler
Strangler's Avatar
Agreed, but without a real hanger I worry about mounting it in there.
Old November 26th, 2012, 04:30 PM   #372
chevotass
chevotass's Avatar
heres what i did.
drilled 3/8 hole in steel rci filler plate. took intank 6.0 pump and hose clamped it to 3/8 threaded rod. used nut on top and bottom with o-rings and bolted 3/8 rod to filler plate. walla.
Old November 26th, 2012, 04:33 PM   #373
Strangler
Strangler's Avatar
I like. But your still having issues, right?
Old November 26th, 2012, 04:35 PM   #374
chevotass
chevotass's Avatar
yes, its not the pump. and 60psi is tougher to acheive than 12.
i ran my rci cell with my tbi motor for 5 years with an inline pump e2000. never failed the internal regulator in the tbi took care of the high pressure i was sending it with the e2000.
Old November 26th, 2012, 06:32 PM   #375
Tacker
Tacker's Avatar
Put a sump in the bottom of your cell and get the pump back farther so it doesn't have to pull so far. I would recommend a nice Aeromotive pump too vs a Holley pump.
Old November 26th, 2012, 06:55 PM   #376
1 ton tj on 40's
it's better to push then pull just like a well on a house.
Old November 26th, 2012, 09:28 PM   #377
Bruster
yuuuuuuuuuuuuuuuuuuuuuup
Old November 26th, 2012, 10:20 PM   #378
bbaXJ
Yooper In Training
bbaXJ's Avatar
It wouldn't help eliminate the pulling instead of pushing, but maybe something like this could help:
http://www.pirate4x4.com/forum/motor...stems-lii.html
Or maybe not, since burning up the pump sounds like the problem, not starving the engine for fuel
Old November 26th, 2012, 11:01 PM   #379
Strangler
Strangler's Avatar
No, that just looks like 9 million potential air leaks/problems. I see no need for all that hardware.
I think I'll make a sump for the bottom that has a larger line size and run large hose to the pump, which I will move closer to the tank. Looks like I need another Blue pump, or similar.
Old November 27th, 2012, 06:12 AM   #380
I think Nick has it right. I fought fuel pump issues for years. Once I went to an in tank pump my problems went away. I've been carrying a spare pump with me for about 4 years and never needed it. Prior to the in tank, I was replacing a pump at least once a year.
I have a hard time understanding how the multiple pickups work any better than a single in the middle. Once the high side can start sucking air I would think it would become the path of least resistance. Maybe the concept is that it always stays primed???
Page generated in 0.35489 seconds with 84 queries
