Starting another one... Currently Functional. - Page 17 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 28th, 2012, 11:51 AM   #321
Strangler
Strangler's Avatar
Threw some more caster at it (to 7 from 4), and switched to a shorter pitman arm last night. I'll build a longer draglink tonight and take it for another drive. I had to change out one of my rubber brakelines as It got crushed somewhere along its journey. All buttoned up now tho.
Rear axle is making noise when I let off the throttle from 30mph+, I'm thinking I didn't get the pinion nut tight enough, or I need another shim or 2 under the pinion support. Noise goes away as soon as I tip into it, kinda wierd.
Old February 28th, 2012, 11:57 AM   #322
fullthrottle
2013 King of da Moustache
fullthrottle's Avatar
Send a message via AIM to fullthrottle
looks great Scott glad you've got her done!
fullthrottle is offline   Reply With Quote
Old February 28th, 2012, 12:05 PM   #323
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I have more shims or u do lol
H.o.r.e
Old February 28th, 2012, 12:34 PM   #324
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i have a bunch of 14 bolt shims also
Old February 28th, 2012, 12:53 PM   #325
kickstand
circling the drain
kickstand's Avatar
Looks good scott, are you going to part it out soon? I would be interested in the 8 ball gussets.
seriously looks good, I like clean and simple.
Old February 28th, 2012, 08:06 PM   #326
liv2mx
i like jungle gym's.
liv2mx's Avatar
looks good scott. can't believe your going to actually be wheeling again. dont roll this one off any cliffs now.
Old February 28th, 2012, 09:18 PM   #327
1 ton tj on 40's
1 ton tj on 40's's Avatar
looks nice. me or ryan will have to get a hold of you on my jeep. i have to help out my bro frist.
Old March 1st, 2012, 10:53 AM   #328
Strangler
Strangler's Avatar
Josh, I tried to text you yesterday but ended up having a nice long discussion with Trailjunkie.... the only Josh I had saved on my phone. Oops.
Get a hold of me, I can come get your Jeep whenever.
Old March 1st, 2012, 11:09 AM   #329
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Lets do this
H.o.r.e
Old March 1st, 2012, 11:10 AM   #330
Bruster
move the passenger seat back some as well josh haha
Old March 11th, 2012, 09:17 PM   #331
Strangler
Strangler's Avatar
<------ = Sad Panda
Trans went kableweyblammo.
Old March 11th, 2012, 09:29 PM   #332
chevotass
chevotass's Avatar
was this my trans? if so i feel bad as it worked good for me. i will make it right cubby. just give me a call
chevotass is online now   Reply With Quote
Old March 11th, 2012, 09:38 PM   #333
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Bummer. You have the technology to build it faster, bigger, stronger.
Old March 12th, 2012, 06:09 AM   #334
Strangler
Strangler's Avatar
Yes Nick it was yours, but I had gone thru it with a very reputable trans builder and threw all the good parts at it. It hasn't really even been used yet, just test drives trying to sort out the steering and such. 1-2 shift felt soft, then all shifts felt soft, now a 10 mile run down the highway netted trans temps of 290* and AFT EVERY-FRICKIN-WHERE and I can make it slip with a strong tip-in. Its coming out.
Old March 12th, 2012, 08:48 AM   #335
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Bummer Scott
I'm the man in White.
Old March 12th, 2012, 08:57 AM   #336
Tom
Because racecar
Tom's Avatar
Did you have the tv cable set properly? It sounds like you didn't have enough throttle pressure which will burn up a 700r4 quick.
Old March 12th, 2012, 09:06 AM   #337
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Gay scott
H.o.r.e
Old March 12th, 2012, 10:28 AM   #338
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
Old March 12th, 2012, 10:51 AM   #339
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Was this the source of your driveline problem, or just one more added to the list?
@clarkstoncracker
Old March 12th, 2012, 11:14 AM   #340
Strangler
Strangler's Avatar
Seperate issue. Driveline noise was a bad carrier straddle bearing in the housing I used.
Page generated in 0.59741 seconds with 85 queries
