ford f 250 build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 24th, 2010, 11:44 PM   #1
bigblockford
bigblockford's Avatar
Post ford f 250 build
basically i have a 1990 f 250 with a 351w but i hurt it at the last mud bog and i wanted to break it i have a built 460 in the garage i have the motor auto tranny flex plate flywheel torqe conv. motor mount on the block already and the spacer on the auto tranny. basically i want to know if i have everything so i can make this a weekend thing with a few buddies and a few cases of beer? so any info will be good. please and thanx
bigblockford is offline   Reply With Quote
Old October 26th, 2010, 08:42 PM   #2
Never_Evil
If its a C6 tranny, it should be fairly close to put it together, fill up your fluids and go. The only piece that may not fit are the drive shafts and you will need a bigger radiator.
Old October 28th, 2010, 09:08 PM   #3
bigblockford
i already have a massive 4 core rad. for it um will the slip yoke for the drive shafts maybe still work due to the slip part?
Old October 28th, 2010, 10:21 PM   #4
camccardell
tiger blood
camccardell's Avatar
the bw 1356 should bolt to the c6, but I think that the c6 is shorter than the e4od. not sure by how much though.
Tags
351w, 460, f 250, ford, motor
Page generated in 0.31311 seconds with 35 queries
