2007ish Ram / Dakota towing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 24th, 2010, 11:33 AM   #1
NSmist
NSmist's Avatar
Send a message via AIM to NSmist
Default 2007ish Ram / Dakota towing
Looking at used 2007 +/- a year Dakotas and Ram's.
2 in specific have the 4.7L V8 and both appear to have some kind of towing judging by the overhaul disable button on the column shifter.
The Ram Quad Cab has a Hidden Hitch on the back and I managed to grab 5000# and 8000# of the label. I wouldn't think the Hidden Hitch brand was the stock receiver installed on them. I've found them on quite a few of the ones with the 4.7's.
The Dakota Quad Cab doesn't have a receiver hitch on the back at all, but there are the 3 holes for a bumper mounted ball. The make or break deal to this would be if I could bolt on a hitch.
Is it safe to assume these already have trans coolers and the works of the towing package installed? I'll probably call a dealer anyways and get the info on them by their VIN's, but would still like to hear some info prior.
NSmist is offline   Reply With Quote
Old October 24th, 2010, 07:09 PM   #2
noodles
give 'er sh*t ay?
noodles's Avatar
i wouldnt assume anything. look up reese.com, or the hidden hitch. im sure you can look up a hitch for the trucks. what all are you looking to tow? im sure there will be more telling you to buy the full size because you are goign to tow. The truth all depends on what you plan on doign wiht it. just remember you will tow more than you plan. Look at the gvrw of the trucks and what your towing.
As for the coolers, you can add aftermarket ones and you should be able to tell just by opening the hood.as for the hitch, mopar has its own so I highly doubt that the hidden hitch was factor.
something else to look at is your space. will a full size fit in your garage, or where you park the truck. would it be easier to get around in a smaller vehicle where you live?
Me personaly, I would go with the full size because I tend to tow towards the gross.
Old October 26th, 2010, 09:57 PM   #3
dline
dline's Avatar
rams come with trans cooler from factory
if it has a 7pin trailer harness, than it has the oem tow package also
dline is online now   Reply With Quote
Old October 28th, 2010, 12:44 PM   #4
firecat
firecat's Avatar
all rams/dakotas have the o/d disable button. the trailer tow package will include a larger trans cooler than the standard one, and one's I've had also had a power steering cooler. without the factory tow package I would make sure the rear axle has good synthetic lube
firecat is offline   Reply With Quote
Old November 2nd, 2010, 07:00 AM   #5
nickb304
nickb304's Avatar
i believe all the 02+ rams have the receiver hitch support that also supports the bumper from the factory and its just a matter of bolting on the actual 2" receiver to that under the bumper if it does not have one. its like a $60 part on-line. 06+ hemi will get the same mpg as the 4.7 with way more power. regardless of what you get here is a good link
http://www.dodge.com/bodybuilder/year.pdf
nickb304 is offline   Reply With Quote
Old November 29th, 2010, 08:41 PM   #6
rockman
look in the glove box to see if it has 3.92 rear end. ALso it will tell if it is anti-spin axle. I have a 03 with the 4.7 and 3.92 and it pulls my camper easy.
rockman is offline   Reply With Quote
Old November 30th, 2010, 07:37 AM   #7
Flat_Black
The Dodge Guy
Flat_Black's Avatar
do some research on the 4.7..... that is all
Old November 30th, 2010, 07:43 AM   #8
greygoose
I'm the dude
greygoose's Avatar
Why is that?
To the OP, I would look for a 2008+ just because you get the 300+ horsepower 4.7 as opposed to the 235hp original. I will say though that the original 4.7 has plenty of power for my Grand Cherokee, and has performed flawlessly over the last 100k miles.
Old November 30th, 2010, 09:42 AM   #9
Flat_Black
The Dodge Guy
Flat_Black's Avatar
Originally Posted by greygoose View Post
Why is that?
im sure it has great power for you gc, but thats like saying your peddle bike is gets better gas milage then a motorcycle.
i was just telling the op to do his research and make sure hes looks at the good AND the bad.. for hauling the hemi would be the better option and reliability. the 4.7 has more then a few flaws.
Old November 30th, 2010, 09:54 AM   #10
greygoose
I'm the dude
greygoose's Avatar
Orly? He did ask about the Dakota as well, which only weights about 400 pounds more than my Jeep. Just sayin...
Old November 30th, 2010, 10:00 AM   #11
Freak
Wheelin the HD
Freak's Avatar
do you tow with your GC? and if so, what do you tow? he is looking for a TRUCK for a reason, so I doubt your GC has anything to do with anything here.
Old November 30th, 2010, 10:04 AM   #12
greygoose
I'm the dude
greygoose's Avatar
Yup, 5000 pound boat thousands of miles a year. He is asking about the 4.7, which I have in my GC and tow with regularly. I think it is somewhat relevant.
Old November 30th, 2010, 10:30 AM   #13
Freak
Wheelin the HD
Freak's Avatar
People tow boats with the weirdest things...
Old November 30th, 2010, 10:51 AM   #14
greygoose
I'm the dude
greygoose's Avatar
I know...
Page generated in 0.44821 seconds with 65 queries
