Wanted 1975 F250 Axle Shaft - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 21st, 2006, 03:17 PM   #1
jdak
jdak's Avatar
Default Wanted 1975 F250 Axle Shaft
I need inner and outer axle shaft for 1975 F250 with dana 44 closed knuckle.
The number on the axle housing is 603245-1. Any help locating would be appreciated.
jdak is offline
Old August 21st, 2006, 03:18 PM   #2
PavementPounder
PavementPounder's Avatar
I don't know what the number means, but do you need the long side or the short side?
PavementPounder is offline
Old August 21st, 2006, 03:25 PM   #3
xj4life
xj4life's Avatar
any idea on what the lenghts are, i might have a set
xj4life is offline
Old August 21st, 2006, 06:00 PM   #4
jdak
jdak's Avatar
Default Axle shaft
The number is whats stamped on the axle housing and when you google it , you can find info on the axle that it was actually 1971 and I cann't remember the rest. I am posting this for my husband so I think by saying we want the inner and the outer that means we want both the long side and the short side.
jdak is offline
Old August 21st, 2006, 06:05 PM   #5
jdak
jdak's Avatar
Default Axle Shaft
8 1/2 " and 18 1/2 "
jdak is offline
Old August 21st, 2006, 06:26 PM   #6
PavementPounder
I know what the number IS - its the Bill Of Materials for the axle assembly itself (the whole thing). It doesn't tell us which set of shafts you need.
You already posted the dimensions, so this is just a quick FYI explanation. Its easier to say which side of the axle you need the pair of shafts from if you know the axle's application (model & year). There are 4 shafts in a front axle and the differential is always off to one side. The outers (stub shafts) are identical, but the two inners are not the same length. There is a long side and a short side.
By the numbers you just posted, it has to be the short side.
Old August 21st, 2006, 07:09 PM   #7
jdak
jdak's Avatar
You said, you didn't know what the number means. I gave the number if someone wanted to look it up they could see the specs or dimensions maybe to match things up. We'll take anything we can get for that axle cause if we don't need it right now, we will need it sometime. At the moment we do need the short side (the driver's side front) We will take the long side too.
jdak is offline
Old August 22nd, 2006, 08:23 AM   #8
PavementPounder
Yeah, I did say that. I also explained to why the BOM doesn't tell us what you needed. Even though you posted the lengths, you didn't know what it was you were asking for until I explained the long side/short side concept.
Based on this description, you could have ended up with two inner shafts. See what I am saying?
Does your husband's axle have drums? Ask him if he would be interested in a complete later 70's axle assembly (upgrade to discs) if he has trouble finding just the shafts that he needs.
Old August 22nd, 2006, 03:56 PM   #9
jdak
jdak's Avatar
We already have too much money in the hydraulics and locker and everything else in the front end. (so don't want to take all that out for discs)
We can find a different axle assembly at salvage yards around here .
We may end up just having to spend more money to have something built.
jdak is offline
Old August 23rd, 2006, 05:47 PM   #10
jdak
jdak's Avatar
Default axle shafts
We're still hoping to find the shafts so anybody please let us know if you have axle shafts we might be able to use.
jdak is offline
Old August 27th, 2006, 06:29 PM   #11
jdak
jdak's Avatar
Got lucky and found someone with an axle assembley by Allegan so I got what I needed and then some. "The Beast is Back" and we'll try to go to Sodbusters in Indiana.
jdak is offline
Page generated in 0.30467 seconds with 56 queries
