609 front axle in leaf sprung CJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 20th, 2010, 10:16 AM   #1
Default 609 front axle in leaf sprung CJ
Considering building a 609 front axle for my cj8, and have a few questions:
1) with the leaf spring spacing on a cj front, how is the packaging side to side with getting leaf perches in there? Likely going to have a passenger drop with a th350 and dana 300 so keeping the pinion as far right is a priority..i'd prefer to go to a spider 9 bujt they are wide. Wasn't sure of the strength of the currie banjo style centers...
2) do the spider 9 offset housings have provisions for inner axle seals?
Old October 20th, 2010, 06:05 PM   #2
95geo
newbie
95geo's Avatar
Inner seals yes, they are on the website. The housing tube to tube is about 18". If you look in the axle shaft page there is a cool excel sheet with some dimensions and profiles on it if it helps at all.
What's your spring pin center distance? I can give you some rough numbers if you need some.
Old October 20th, 2010, 06:49 PM   #3
I found that dimension on their website, I guess I need to go see what my pinion offset is today.
Page generated in 0.12085 seconds with 32 queries
