94 ranger oil pannnn - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 19th, 2010, 10:36 AM   #1
AZTEC
AZTEC's Avatar
Default 94 ranger oil pannnn
My friend has a 94 Ranger 3.0L V6 and the oil pan needs to be changed. We tried to change it before but couldn't get it off because of the front suspension parts. I was told by a couple of other people that we have to lift the motor up a little bit in order to do it but neither of us have a crane for it. Does anyone have any suggestions?
AZTEC is offline   Reply With Quote
Old October 19th, 2010, 07:06 PM   #2
Yota Bill
tree and a come-a-long, or find a cherry picker to borrow...could also lift it with a floor jack and blocks of wood, but thats a PITA to reposition....
Whatever way you use to lift it, set blocks of wood between the motor mounts and set the engine back down on those, dont leave it suported only by the lifting device while your working in there, unless you would like to have a trip to the ER, and permanent injuries like missing fingers
Old October 19th, 2010, 07:31 PM   #3
AZTEC
AZTEC's Avatar
We might use a cherry picker actually. But where would you hook it to? And what should I use to pull it up, chains?
Old October 20th, 2010, 06:48 AM   #4
turnofftheradio
ive lifted plenty of engines using some 2x4" across the engine compartment with chains/tiedowns and a couple of buddies on each end. think indiana jones and the arc, or some natives with a pig to carry home. easier than you think with a few friends... kinda ghetto though.
turnofftheradio is offline   Reply With Quote
Old October 21st, 2010, 04:44 AM   #5
Yota Bill
yes, you connect it with chains, either bolted on (check the back of the heads and you will find empty bolt holes, remove whatever accessories you need to on the front and use those same bolt holes in the front of the head) or by using the factory installed lifting eyes, if they are still there
Old October 26th, 2010, 02:19 PM   #6
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
first step in all-data says, remove engine.
Old October 26th, 2010, 09:54 PM   #7
Yota Bill
dont you work flat rate?
Old October 29th, 2010, 09:41 AM   #8
04 EDGE
04 EDGE's Avatar
no. commission/salary. And honestly if this job were in my bay, I think I would just pull the motor. On a lift and a engine hoist this is not a hard job.
Page generated in 0.23556 seconds with 47 queries
