Jeep lift - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 21st, 2006, 08:24 AM   #1
Jeep8499
'78 CJ7 - Rebuilding -
Jeep8499's Avatar
Default Jeep lift
Looking for a 3" or larger body lift for my '93 wrangler. Let me know if you have something.
Thanks.
Jeep8499 is offline   Reply With Quote
Old August 21st, 2006, 08:39 AM   #2
PavementPounder
PavementPounder's Avatar
Thumbs down No!
You don't want a body lift larger than 3". I can't think of anybody that even sells anything over 3" because they are not safe due to the relatively low number of body mounting points (compared to other vehicles, like a full-size). Don't "engineer" one beyond 3", either.
Personally, I would look towards suspension options first. There have been a lot of YJ lift springs on the board lately if you haven't already done the suspension and just want more lift beyond that.
Old August 21st, 2006, 09:09 AM   #3
Nrth
trolling
Nrth's Avatar
I've got some barely used 2" BDS springs for a YJ. Will net around 2.5-3" PM me if your intrested.
Heres a link to the post:
http://www.greatlakes4x4.com/showthread.php?t=18507
Nrth is offline   Reply With Quote
Old August 21st, 2006, 10:24 AM   #4
busyfixin
Balls Deep
busyfixin's Avatar
body lift over 3" is illegal for road use in michigan, probably most other states as well, thats why you dont see them for sale anywhere.
Old August 21st, 2006, 11:10 AM   #5
PavementPounder
And why might they be illegal? :miff:
I doubt the manufacturers care that much about what Michigan specifically allows that they would make a production decision on it. They don't do that much business in Michigan alone for it to dictate their operations. Same for the large online distributors. In this case, its a "bad idea for this application" thing, not a "they said no" thing. If you do some research, you will find body lifts over 3" for other vehicles.
Old August 21st, 2006, 11:18 AM   #6
biohazardbill
The Biohazards
biohazardbill's Avatar
Maybe because Mi law says so lol
Section 257.710c
(4) Notwithstanding subsection (2), a person shall not operate a motor vehicle having lift blocks between the front axle and springs, or with lift blocks that exceed 4 inches in height between the rear axle and springs in addition to those provided by the original manufacturer. Any body lift block shall be of single piece construction and shall not use more than a 3-inch spacer. Any suspension lift block shall use an alignment pin between the axle and the spring, and shall be of single piece construction. Spring shackle replacements shall not exceed the original equipment manufacture length by more than 2 inches, and coil spring spacers are prohibited. All steering components shall be geometrically arranged to function as original equipment manufacture. Welded pitman arms, drag links, and tie rods are prohibited. All parts used to modify the original suspension or height of a motor vehicle shall be factory manufactured and shall meet or exceed the original manufacturer's specifications.
biohazardbill is offline   Reply With Quote
Old August 21st, 2006, 11:32 AM   #7
PavementPounder
Because its unsafe, ass. I seem to recall you posting that you were looking for a body lift bigger for 3" for the FSJ. Many members on this board have all kinds of shit on their rigs that is technically illegal.
Old August 21st, 2006, 11:56 AM   #8
Jeep8499
Jeep8499's Avatar
Thanks for the replys. Dont know alot about lifts, but I just bought an old cj7, and the guy told me it had a 4" body lift on it. I just checked it out, and its actually a 3" lift instead of 4. Thanks again for the help.
Old August 21st, 2006, 08:12 PM   #9
Sonicjay
Section 257.710c
:tonka:
Sonicjay is offline   Reply With Quote
Old August 21st, 2006, 08:14 PM   #10
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
my jeep is technically illegal and anyone else running a budget boost
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Old August 22nd, 2006, 12:17 AM   #11
busyfixin
Balls Deep
busyfixin's Avatar
im sorry, PP i meant that i thought they may be illegal in all the other states as well, being that ive never seen them for sale by a manufacturer. honestly ive never searched, or researched any form of body lift, since i dont give a crap about them. i just happened to know that they are illegal in MI. not that i really give a crap about being totally legal either.
Old August 22nd, 2006, 12:59 AM   #12
Tonka
Tonka's Avatar
The budget boosts for the newer jeeps are perfectly legal. They are larger coil isolators if going by the O.E.M. part name.
Old August 22nd, 2006, 10:00 AM   #13
Quagmire
yes but only if you remove the stock isolator othwise you are stacking liftblocks
Old August 22nd, 2006, 10:15 AM   #14
silverxj
Recovering XJ owner
silverxj's Avatar
X2
Besides I thought this thread was about body lifts?
Page generated in 0.38081 seconds with 65 queries
