are solid axles better - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > The recycle bin.
The recycle bin. Posts deemed annoying. If you see your post here, take a hint.
Old August 20th, 2006, 05:45 PM   #1
carguy64744
Default are solid axles better
would it be better on my 90 k2500 to have a solid front axle or what i have know
how hard would it be to switch it can i just flip the axle so the drive shaft on the axle will be on the ds or would it need to be modofied on the inside
carguy64744 is offline   Reply With Quote
Old August 21st, 2006, 11:33 PM   #2
Symmes
Look on here for lifts.
www,fabworxoffroad.com//////www.offroaddirect.com
Symmes is offline   Reply With Quote
Old August 22nd, 2006, 11:39 PM   #3
carguy64744
nice to know they make a kit can i use an entire chevy frame will it bolt to my body one from like a 79 or 82 chevy has anyone ever done this before
Old August 25th, 2006, 08:50 PM   #4
user name
keep your stick onthe ice
user name's Avatar
the frames a dif width i have seen other people put the older frames under a newer body but they never see road use. if you go solid axle look for a ford axle the drop will be on the driver side.
Old August 27th, 2006, 09:51 PM   #5
carguy64744
will it make a diffarence which side the drop is on can i just flip the axle
Old August 28th, 2006, 09:41 AM   #6
amc78cj7
amc78cj7's Avatar
Are you serious?
Yes, a solid axle is better.
No, you cannot just "flip" an axle to get the pumpkin on the right side.
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old August 28th, 2006, 11:44 AM   #7
PavementPounder
PavementPounder's Avatar
Why would you want to flip anything when driver-drop axles are available? The vast majority of high-pinion axles are driver-drop and stronger anyway.
Old August 28th, 2006, 01:45 PM   #8
amc78cj7
amc78cj7's Avatar
I don't know PP, I think I'm gonna flip my rear D60 so it's high pinion. The pumpkin's in the middle so it won't matter. Just cut and weld my spring perches on the other side and I should have the job done in 30 minutes.
Actually, now that I think about this some more, this would be the ideal way for stock CJs to go SOA AND High Pinion without ever having to cut or weld..... :tonka:
Old August 28th, 2006, 02:36 PM   #9
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
I thought if you flipped 60's there were lubrication (or lack of) issues?
Old August 28th, 2006, 03:36 PM   #10
roll-bar Bob
roll-bar Bob's Avatar
if you flip a 60 over you just get 09
now what happened to the other 51
rbb
Old August 30th, 2006, 10:31 AM   #11
carguy64744
well i have a chevy truck rolling chassis but driveshaft is on the ps mine is on the ds and i want to keep my trans mine is 32 spline the older ones that drop on the ps are not so either need a ds axle or a transfercase to fit my trans with a ps driveshaft and funds are limited so i was trying to use parts i have if possible might be easier to use an older transfercase if there is a way to make it fit my trans or use an older trans and tcase but mine is rebuilt or just get a ds drop axle which years of truck have ds drop solid axle what is the best axle to look for
Old August 30th, 2006, 10:57 AM   #12
PavementPounder
1. You need to locate the . (period) button on your keyboard.
2. Search Google for HP60.
Old August 30th, 2006, 10:47 PM   #13
carguy64744
found this to be very helpfull http://www.fullsizechevy.com/forums/...ad.php?t=59097
Old August 31st, 2006, 04:48 AM   #14
halfgassed
halfgassed's Avatar
offroad unlimited makes a straight axel swap kit for newer chevy's, I can let ya know how good mine goes when I'm done wiht it, although I have to start on it first. IIRC to run a older style chevy solid axle you can use a np 208 t case from a mid 80's chevy that came with the 700r4 trans (I'm assuming thats whats in your 90) with out having to buy adapters or anything, should bolt in but don't take my word for it, call the guys at advance adapters or some place similar.
halfgassed is offline   Reply With Quote
Old August 31st, 2006, 05:38 AM   #15
PavementPounder
Yes, it told you to look for what I told you to look for - a HPD60. :tonka:
Old September 2nd, 2006, 12:44 AM   #16
carguy64744
i had a 700 r4 i now have a 465 from an 88 k2500 i dont like autos at all
Old September 13th, 2006, 09:40 AM   #17
BigBlueBurban
Temporary Web Wheeler
BigBlueBurban's Avatar
learnum to speakum. If he wants to flip the damn axle, let him flip it. He'll just find out the not-so-easy way to go about this and make a better choice next time. :miff:
BigBlueBurban is offline   Reply With Quote
Old September 13th, 2006, 10:10 AM   #18
PavementPounder
Its not "Easy vs. Not-So-Easy". Its "Work vs. Won't Work". You can't flip the axle - it will rotate in the wrong direction. The front axle will be driving backwards and the rear axle will be driving forward.
Old September 13th, 2006, 12:47 PM   #19
Berwolf
Then how do you put reverse in a car? Axles rotate both ways. I thought as previously mentioned it was an oiling issue.
Berwolf is offline   Reply With Quote
Old September 13th, 2006, 01:48 PM   #20
PavementPounder
I can't even believe you actually posted that. Go spend a few years here: http://auto.howstuffworks.com/automobile.htm
IF YOU FLIP AN AXLE UPSIDE DOWN, THE WHEELS WILL BE ROTATING IN THE OPPOSITE DIRECTION. THINK ABOUT IT.
Page generated in 0.33244 seconds with 82 queries
