89 Super Coupe, pulling engine codes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 12th, 2010, 04:20 PM   #1
shawn
Resident HVAC/R Jambi
shawn's Avatar
Default 89 Super Coupe, pulling engine codes
Is there a way to find out stored engine codes on one of these without a scan tool? I have an OBD2 reader, do these work on earlier models?
Old October 12th, 2010, 06:29 PM   #2
prozak1986
prozak1986's Avatar
i had a 92 SC and took it to autozone to pull a code and there was like 10 old codes they found , not sure what scan tool they used thow
prozak1986 is offline   Reply With Quote
Old October 12th, 2010, 09:54 PM   #3
Never_Evil
89 supercoupe will still use OBD I, standard ford under the hood connector. You can either buy a scanner from auto zone for 30ish bux or you can jumper it and count the flashes.
Old October 12th, 2010, 09:56 PM   #4
Yota Bill
there is a way to hook up a couple jumper wiress to the DLC, and use the MIL to flash the codes..I cant remember it off the top of my head right now (always had a way to read codes on Fords, have only done the jumper wires to try it)
I'll search and see if I can find it for you.
*edit- found it*
http://www.therangerstation.com/tech_library/OBD_I.html
that shows how to pull codes using the MIL, a test light, or an analog voltmeter (note: not digital) notice it also shos where the fuel pump test location is...thats a pretty handy one right there
Old October 13th, 2010, 09:48 AM   #5
shawn
shawn's Avatar
thanks guys
Old October 13th, 2010, 11:50 AM   #6
Bones
Bones's Avatar
shawn, I have a simple tool to pull OBDI ford PCM codes....
Or just take it to autozone. What is the issue?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 14th, 2010, 08:19 AM   #7
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
I thought OBD1 didnt save a history of codes?
ATOMIC_BADBOY is offline   Reply With Quote
Old October 14th, 2010, 08:27 AM   #8
Freak
Wheelin the HD
Freak's Avatar
Last I knew auto zone didn't read codes on older cars?
Old October 18th, 2010, 11:15 AM   #9
shawn
shawn's Avatar
Trying to help a friend at work, he is having all sorts of issues. Runs horrible sometimes, ok at other times. Seems to have no power. Tried pulling codes and nothing comes up (he said he bought some cheap reader but nothing is comming up, and the engine light is on). Not sure where to start on this one.
Old October 18th, 2010, 11:58 AM   #10
Bones
Bones's Avatar
The super coupe is super finnicky for needing clean spark plugs and a constant fuel pressure. I would start with new plugs and a new filter, but generally neither of those would set a CEL.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old October 18th, 2010, 12:05 PM   #11
prozak1986
prozak1986's Avatar
i know on my SC there was a vac line on the back of the supercharger that broke and it ran like crap , my CEL light came on and said my TPS , IAC and a few other sensors were bad so i replaced them and still had the same issue , long story short after spending about 400bucks it ended up being a 5dollar fix
check for broken vac lines , theres a ton on that car
Old October 18th, 2010, 12:09 PM   #12
prozak1986
prozak1986's Avatar
very true , these motors are real picky , another thing is the plugs ( only use basic champions IMO ) tell him to change the plugs ( the ones on the drivers side are a bitch and its easier to do them from under the car )
Page generated in 0.21818 seconds with 59 queries
