51 chevy truck help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 19th, 2006, 11:55 PM   #1
carguy64744
Default 51 chevy truck help
got a 51 chevy truck i am trying to find out what the wires are that come from the column what wires go to the gauges and ignition there are wires there know somone started wiring it and never finished
carguy64744 is offline   Reply With Quote
Old August 20th, 2006, 09:48 AM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
there should be switched power to the ignition and the starter soliniod. the charge gauge for the generator should be on its own circut. the only other wire should go to the radio & the regulator to shut off the field. I'll see if I still have a diagram
Yetti
Old August 20th, 2006, 10:01 AM   #3
Yetti
Yetti's Avatar
Yetti
Old August 20th, 2006, 10:39 AM   #4
Icemanii
GLFWDA Land Use Committee
Icemanii's Avatar
I have a '49 Chevy sitting in my garage. When I get home tonight I can look at what goes where (maybe) and let you know. I can tell you, these are pretty simple as far as wiring goes, not a lot there.
Let me know if you need this.
Icemanii is offline   Reply With Quote
Old August 20th, 2006, 06:43 PM   #5
carguy64744
yeah i dont see alot of wires somone else has cut all the wires i am going to start wiring it soon i hope its not mine i dont think it should be to hard to figure out will let you know how it goes thanks
Old August 20th, 2006, 09:11 PM   #6
Icemanii
Icemanii's Avatar
Sorry, just got done with the lift and brakes on MudnYJ's heep. Little late and dark to try to figure the pics out. Will look at it as soon as I get home from work.
Also, try this for help.
http://chevytruckworld.tenmagazines.com/forums/
These guys should have what you need right on their computers somewhere. Hope this helps, if not, I will take photos on Monday evening.
Page generated in 0.19777 seconds with 41 queries
