2003 Silverado Blower motor relay - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 19th, 2006, 01:17 PM   #1
Nvrenuf
Nvrenuf's Avatar
Default 2003 Silverado Blower motor relay
Does anyone know if there is a relay for the blower motor and if so where?
The blower fan has started running at full speed without the ignition on or the fan speed dial on. I pulled the fuse to stop it for now.
Any help would be great!
Steve
Old August 22nd, 2006, 11:32 AM   #2
AWK
AWK's Avatar
It is located under the dash on the right side. Remove the hush panel and it's located next to the blower motor. Two screws will remove it. There is a three wire connects going in, then a two wire pig tail comming out. This pigtail goes to the blower motor. We already spoke about this, but I thought I would post this just incase other inquring minds wanted to know.
By the way, you have the manual HVAC.
AWK
AWK is offline   Reply With Quote
Old August 22nd, 2006, 10:04 PM   #3
Nvrenuf
Nvrenuf's Avatar
Thanks AWK
I pulled it out and some traces are burnt.
Steve
Page generated in 0.23932 seconds with 32 queries
