sold 10-18-10
I have a matching set of jeep cj Wide track Dana 30 front axle
and Dana 44 rear axle with 3.31 gear ratio out of a 1986 cj7.
They are complete and come with superior upgrades.
-M.O.R.E offroad heavy duty spring perches front and rear that
give you the ability to move the axle forward or backward 1".
- Custom heavy duty swaybar mounts.
- Custom heavy duty shock mounts.
- Dynatrac U-bolt flip kit for extra ground clearance
As mentioned these axles are complete and come with both steering
arm for the front axle. And they both have good brakes all the way
around. These axles came out of a very clean 1986 cj7 from california
with low miles.
I am selling them due to clearance issues with my updated drivetrain.
I was planning on running a 5.3l engine/4l60e transmission/ dana 300.
Once I bought my adpater and bolted the dana 300 up to the 4l60e
I knew there was no chance it was going to work. So after a ton
of research and decision making I have gone another route.
**click on the link to read more about it: http://www.cj-8.com/forum/showthread.php?t=19469 ***
But this opens an operatunity for someone else to own these axles.
They are bolt in ready. The only things that need to be done(and not in this order):
-primer
-paint
-rear spring perches need to be welded in.
I did not set the rear spring perches because I wanted to get the
proper pinion angle once all the weight was on the jeep. The axles
are bare metal right now but cover with WD40.
click on the links below for pic's
http://i198.photobucket.com/albums/aa15/apowalie1/DSC00719.jpg
http://i198.photobucket.com/albums/aa15/apowalie1/DSC00720.jpg
http://i198.photobucket.com/albums/aa15/apowalie1/DSC00875.jpg
dana 44 wide track rear axle
http://i198.photobucket.com/albums/aa15/apowalie1/DSC00866.jpg
http://i198.photobucket.com/albums/aa15/apowalie1/DSC00881.jpg
dana 30 wide track front axle
http://i198.photobucket.com/albums/aa15/apowalie1/DSC00879.jpg
These are the cleanest cj axles I have seen to this day. All the
welding and modifications were done at a profesional shop. If you have
any questions feel free to pm here at the forum or call me at 440-773-0534.
They are still under my cj8 project right now as we speak.
thanks,
7jeeps7kings(Drew)
with low miles.
-primer
-paint
thanks,
7jeeps7kings(Drew)
