2000 Xj axle upgrade - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 5th, 2010, 02:28 PM   #1
Ebrown
Ebrown's Avatar
Default 2000 Xj axle upgrade
The G-friends 2000 Xj has 4 wheel abs, lp dana 30 and a open dana 35 rear. She would like to keep the 4 wh abs. The dana 35 rear axle is starting to bang pretty bad ( Carrier cross pin ) has egg out the carrier alittle. So what would be a better upgraded axle to install under her Xj and still be able to keep the abs? For the front axle I was thinking Hp Dana 30 but what year is the best to use?and for the rear axle i was thinking a 8.25 or dana 44 with a Diy locker or limited slip for better traction. Did the dana 44 or 8.25 ever come with abs or can I just disable the abs on just the front or rear axle or Both with out tripping a fault in the computer and have a abs light come on?
This is her mall wheeler / two track and the tires size are 31X10.50X15
Ebrown is offline   Reply With Quote
Old October 5th, 2010, 03:50 PM   #2
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
For the front you should be able to swap the knuckles and everything outboard from there onto a HP housing and keep the ABS.
When I did an axle swap in my TJ I solve the ABS light problem by removing the bulb.
brewmenn is online now   Reply With Quote
Old October 5th, 2010, 09:18 PM   #3
Ebrown
Ebrown's Avatar
I've used the same high speed trick before, She not dumb both shit like that!
Page generated in 0.13302 seconds with 32 queries
