94 F150 gearing question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 3rd, 2010, 09:20 PM   #1
deathbypsi
Brian R.
deathbypsi's Avatar
Default 94 F150 gearing question
I just picked up a 94 F150 with a 5.0/aod combo to use as my new daily driver/tow vehicle. I know its not the best option but its way better than the 99 Ranger I was using before and the price was to good to pass up.
Right now its sitting on some 235/75-15 tires on steel rims and Im pretty sure it has 3.55 gears. Im goin to get new General Grabber AT2 31x10.5 for it on aluminum wheels and plan to swap a stock L/S and some 3.73 gears I have.
Do think this would throw the speedo off much or is it going to be a wash pretty much? And if I ever decide to up the gear to 4.10's or drop back to a 28-29" tire how do you re-calibrate these to keep the speedo correct?
Old October 7th, 2010, 11:15 PM   #2
big_ol_bronco78
Psalm 40:2
big_ol_bronco78's Avatar
just need to get the right speedo gear for the gears. i'd imagine the 31's and 3.73 wouldn't throw it off by much. also, you sure that trans is an AOD, thought that year had the e4od?
big_ol_bronco78 is offline   Reply With Quote
Old October 8th, 2010, 05:37 AM   #3
deathbypsi
Brian R.
deathbypsi's Avatar
Actually it has the pan of a AOD so Im assuming its a AODE. I talked to a couple different trans shops before I ordered my TransGo shiftkit and I was told it could be any of those 3.
Old October 8th, 2010, 07:57 AM   #4
fsumotorhead
N8KVB
fsumotorhead's Avatar
my brothers 96 bronco got the speed off the rear abs sensor on the 8.8. When we regeared it from 3.55 to 4.10, the speedo was accurate according to the GPS, whithout doing anything.
Old October 9th, 2010, 12:50 PM   #5
big_ol_bronco78
Psalm 40:2
i forgot to say that, i think best way is just to do GPS if you can. also, if it has a TV cable up to throttle for kickdown on trans, it's an AOD. of it's electronic then it's the AODE or E4od
Old October 10th, 2010, 09:44 AM   #6
deathbypsi
Brian R.
deathbypsi's Avatar
It does have a TV Cable. You sure it couldnt be a AODE? I didnt think the AOD got the on/off button for OD.
Old October 14th, 2010, 10:17 PM   #7
akojsp
akojsp's Avatar
The speedo is electronically calibrated on that. Google it. Easy as pie. All you need is a jumper cable from cable under the glove box and a calculator. I lost all my bookmarks otherwise I would post the link. There are several. Takes longer to get the crap together than it does to program.
akojsp is offline   Reply With Quote
Old October 15th, 2010, 05:47 AM   #8
deathbypsi
Brian R.
deathbypsi's Avatar
I did in fact find out it is the aode. I mistaked the cruise control cable for the tv cable.
I will look for whatever it is your talking about.
Old October 17th, 2010, 09:49 PM   #9
akojsp
akojsp's Avatar
Here is one that I found:
http://www.ford-trucks.com/forums/77...libration.html
Page generated in 0.25600 seconds with 50 queries
