locker - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 2nd, 2010, 09:44 AM   #1
4ponion
Default locker
Hello all. Has anybody put a locker in a 90 4Runner that has a 4 ponion setup if so what did you do
Thanks 4ponion.
4ponion is offline   Reply With Quote
Old October 10th, 2010, 08:34 AM   #2
Suta99
Suta99's Avatar
what is a 4 ponion setup
Old January 7th, 2011, 09:30 AM   #3
Jbissell
I've been working with a 92 Toyota Pickup. The 2 and 4 pinion ( I believe you are referring to the spider gears in the differential?) aren't much different. Depending on what locker you get, it may just replace the 4 gear setup. For instance, I have a 2 gear setup:
The smaller gears connecting the Side Differential gears are what you are referring to I think. In any case, it will all depend on what locker you want to put in.
I am using an ARB air locker, which is the same for 2 or 4 gear set up. It replaces the whole carrier gears and all.
Josh
Jbissell is offline   Reply With Quote
Old January 7th, 2011, 09:58 AM   #4
If you are ordering a lunchbox locker, like a lock rite, you need to get the correct one, either '4 cyl' for 2 pinion or 'V6/Turbo' for 4 pinion...
Old January 7th, 2011, 10:00 AM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
just weld it
H.o.r.e
Old January 7th, 2011, 10:04 AM   #6
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Thanks 4ponion.
I can't make myself pronounce that word in my head.
Old January 7th, 2011, 10:11 AM   #7
Suta99
Suta99's Avatar
Its funny how he spelled it wrong in his username
Old January 7th, 2011, 10:35 AM   #8
Jbissell
lolz. Mmm... Can user names be edited?
Page generated in 1.04127 seconds with 47 queries
