My project TJ**pretty much finished** - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 20th, 2007, 12:41 AM   #61
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Originally Posted by TJontherox View Post
Actually if you look close enough the bleeder is up on top, the air line is tapped into the banjo bolt hole. Thanks for the heads up though.
I see now, my eyes are playing tricks
Old March 21st, 2007, 04:03 PM   #62
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Wheel wells turned out nice.
Old March 21st, 2007, 04:52 PM   #63
83CJ7
Got 360?
83CJ7's Avatar
Looks great!
83CJ7 is offline   Reply With Quote
Old March 21st, 2007, 05:09 PM   #64
TJontherox
Mall Rated
TJontherox's Avatar
Send a message via Yahoo to TJontherox
I think I changed my mind on what I want to build. I think I'm going to go for the Texas hillbilly mud truck. I put my air shocks on today to test flex it and with the air pressure they shipped them with, the shocks stayed fully extended.
32" from ground to bottom of frame rail. :tonka:
TJontherox is offline   Reply With Quote
Old March 21st, 2007, 05:12 PM   #65
Gunsworth
Gunsworth's Avatar
wow, looks like you are ready for some 342 inch tires
Gunsworth is online now   Reply With Quote
Old March 21st, 2007, 05:14 PM   #66
TJontherox
Mall Rated
TJontherox's Avatar
Now for the real flex test. I let some air out of my shocks to do some flexing.
2" below ride height.
Old March 21st, 2007, 05:15 PM   #67
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
With how clean you were building it, I kinda figured you were going for a show truck theme.
I'll bet you'd be fine running 54" boggers on those D44s.
Old March 21st, 2007, 05:17 PM   #68
TJontherox
Mall Rated
TJontherox's Avatar
Now for the rear tire.
Old March 21st, 2007, 05:22 PM   #69
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Ok, so now there's some new pics. Looks good. Any rubbing on the rear shocks? Looks like it's close but ok.
The suspension looks good, whoever set that up is a genious. The fabricator's not bad, either.
Old March 22nd, 2007, 09:40 PM   #70
General Lee
Slice of Starsage Anyone?
General Lee's Avatar
Send a message via AIM to General Lee
Ryan...dang dude...
Wanna slip some 35s under my new Cherokee?
General Lee is offline   Reply With Quote
Old March 23rd, 2007, 11:01 PM   #71
BIGBEN
All out Idiot
BIGBEN's Avatar
looks like you are getting more flex out of the front axle than the rear.
still looks good.
with the reworked rear wheelwells, will you still be able to fit a tj seat. or are you switching to a yj/cj/aftermarket seat. just looks a little tight for the stock seat.
Originally Posted by Stan View Post
My hope is that one day all women will realize just how well they could have it if they just shut their big fucking whining mouths.
BIGBEN is offline   Reply With Quote
Old March 24th, 2007, 08:50 AM   #72
TJontherox
Mall Rated
TJontherox's Avatar
still looks good.
No, I still get more out of the rear, only by a couple inches though. My brother in law gave me a f an t rear cj seat, I haven't gone to pick it up yet though. It should fit in there nicely.
Old March 24th, 2007, 09:09 AM   #73
Paul04TJ
Small, but talented
Paul04TJ's Avatar
You live the Sterling Heights, what shop to you work at?
I may need help fabbing up a swingout for my bumper.
Paul04TJ is offline   Reply With Quote
Old March 24th, 2007, 10:10 AM   #74
Big Daddy Rubicon
There watching me! (.)(.)
Big Daddy Rubicon's Avatar
Great job!
[QUOTE=a.j. hall;1528363]
[/QUOTE]
Old March 25th, 2007, 04:24 PM   #75
TJontherox
Mall Rated
TJontherox's Avatar
I finally got ahold of a 2" die for the bender this weekend to finish my cage and rear bumper. It only took about a month to track one down.
Nothing too exotic on the cage, but should hold up to a minor roll.
My cage mount will go on the end of the frame and be cut around the tube for the rear bumper.
There will be 2 tubes going forward to a cross member I welded in earlier to tie in the bumper from front to back. Then bump stops will also come off of those 2 tubes. I will also put on a couple shackle hangers for recovery
Old March 25th, 2007, 04:25 PM   #76
TJontherox
Mall Rated
TJontherox's Avatar
Shop is at 16 and Mound
Old March 25th, 2007, 05:40 PM   #77
BIGBEN
All out Idiot
BIGBEN's Avatar
i was wondering how you were going to tie the ends of the frame together.
looks really good.
hope you don't mind, i am going to copy some of your ideas onto my own tj.
Old March 28th, 2007, 12:54 PM   #78
89yj
89yj's Avatar
how does it stay up with out any springs? Where did you score the sweet insta trunk for so cheep? It looks like the drivers front wheel is locked up. Is it going to be street legal w/ the departure angle and the aproach angle?
89yj is offline   Reply With Quote
Old March 30th, 2007, 02:27 PM   #79
89yj
89yj's Avatar
i need 42's under my cj. Can i drop it off at your shoppe.
Old April 3rd, 2007, 06:09 PM   #80
TJontherox
Mall Rated
TJontherox's Avatar
I got a chance to do a tummy tuck on it this weekend. I got rid of the big shovel for a cross member/skid plate. I needed a 2" body lift instead of a 1" to get a true flat belly skid but the tuck should do fine.
I clocked a redrilled the 300 t case to be above the cross member. I had to introduce to floor to a hammer to clear for the indexing, its under the seat so you can't see it.
pic of the rear recovery shackle mount.
front recovery mount
I started to do cable twin stick on the 300 also. Will post pics up in a bit.
Page generated in 0.29235 seconds with 83 queries
