My project TJ**pretty much finished** - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 17th, 2007, 11:20 AM   #21
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
That sounds pretty good. My rear tire just barely rubs the shock body and it's a little closer, so you should get by without any rubbing, or at most, very little rubbing.
Old January 17th, 2007, 09:29 PM   #22
TJontherox
Mall Rated
TJontherox's Avatar
Send a message via Yahoo to TJontherox
Forgive my crude paint skills but this is to give an idea as to what I would like to do to the frame. I will allow me to mount the shocks under the frame straight up and down to keep from unloading too much while side hilling. The frame will still continue straight side to side and allow me to put c/yj wheel wells with a bump on top for the frame and put a cj rear seat in it. I think the frame should be strong enough to do this it is 4" tall 2.5" wide with roughly 3/16" thick walls and a couple crossmembers. Plus I will have added strength with the cage tied to the frame. Just trying to think outside the box a little, anyone can cut holes in a tub and run a jungle gym in the back. I just think it would be cool to have a capable long travel suspension and not have to cut up the interior of the Jeep. Call me crazy I guess, I'm sure people thought the Wright brothers couldn't get a plane to fly and they did, so we'll see what happens.
The rear frame horns will have a bracket on it to tie the rear corner of the cage to them. The cage will be tied into the frame and I will put downtubes in the front so it will be the typical 6 pt cage til funds allow for a new cage.
TJontherox is offline   Reply With Quote
Old January 29th, 2007, 09:51 PM   #23
TJontherox
Mall Rated
TJontherox's Avatar
Got some rear frame rails made up now. They are the same height, width and thickness as the factory frame, so they should be strong enough. There is a plate running behind the mitres to tie the three pieces together. All the little dots are plug-welds to a piece of 3/16" plate along with the joints welded.
This is what the frame looks like from the side now. Little goofy but functional for my needs. When the body goes on it won't look that much different. The mock up shock will be centered in the upper part, it is just leaning in there to give an idea where it will be.
All the little dots at the radius of the factory frame are going to be more plug-welds to 3/16" plate just like at the top, both the inside and outside of the frame rails.
Old January 29th, 2007, 10:05 PM   #24
TJontherox
Mall Rated
TJontherox's Avatar
This is what it looks like from the side with the body on it. When the frame and inner wheel well are painted black you'll hardly notice the frame.
The rear frame horn will have a bracket to tie the factory cage to the frame.
Pic from the inside. The tube under the frame is only there to hold the the new frame on place. I plan on putting YJ/CJ fender wells in it to finish of the rear of the tub. The top 5" of the frame rail will poke through the top of the well.
With any luck I may have the rear about 90% mocked up and ready for the complete weld. At least enough to move to the front to make shock hoops and get this sitting on all 4's soon.
Old January 30th, 2007, 01:36 PM   #25
muddy maki
Its tough out there.
muddy maki's Avatar
Send a message via AIM to muddy maki
thats allmost exactly what i was planing to do to my tj later on.
looken good.
muddy maki is offline   Reply With Quote
Old February 21st, 2007, 07:11 PM   #26
TJontherox
Mall Rated
TJontherox's Avatar
I now have my rocker guards and crusher corners made and installed. I used carriage bolts to fasten them to the tub. I was in a debate on what color to paint the Jeep when finished but with the bolt heads lookin like rivets on a tank it may just have to be painted OD green
The blank cut out before bending around the rear corner of the tub.
Crushe corner clamped in place and partially bent around the rear of the tub.
Completely installed corner with comp cut.
The old skin of the tub will be beaten over to make a factory looking flange. I haven't decided on what tail lights I want yet to have to cut the hole. That will have to wait for a later time. I know I'm gonna get LED's Though.
Old February 21st, 2007, 07:14 PM   #27
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
looks really good.
nate4d is offline   Reply With Quote
Old February 21st, 2007, 08:08 PM   #28
TJontherox
Mall Rated
TJontherox's Avatar
I also had to cut my underside of the frame rail a bit to allow the control arm to get full suspension movement. I only have 4" up-travel but the control arm would hit if I didn't notch it a bit. It now has clearance for 6" up-travel.
Old February 21st, 2007, 10:54 PM   #29
98tjbme
98TJ soon to have 4" lift
98tjbme's Avatar
Send a message via AIM to 98tjbme
You are frikkin sweet. I strongly admire the fact that you know how to do all of this. The rig is badass!!!
98tjbme is offline   Reply With Quote
Old February 26th, 2007, 09:13 PM   #30
TJontherox
Mall Rated
TJontherox's Avatar
I got my cage all finished this weekend. First time using a tube bender, turned just as I expected. I know most of the stuff I'm building for this could be bought, but I get more satisfaction out of building it myself, plus I don't have the money to buy all the parts off the shelf.
I also started bending up my tube fenders. I hope to be done fabbing these up tomorrow.
Old February 26th, 2007, 09:21 PM   #31
mpsbvp
Hummer recovery team
mpsbvp's Avatar
Send a message via AIM to mpsbvp Send a message via Yahoo to mpsbvp
looks real good
mpsbvp is offline   Reply With Quote
Old February 26th, 2007, 09:22 PM   #32
Chop
Mischievous Badger
Chop's Avatar
your making progress man its lookin good
Old February 26th, 2007, 09:32 PM   #33
Dave Kerwin
web wheeling, hard.
Dave Kerwin's Avatar
I can't say I understand the frame thing, but its evident by the rest of it that you know what you are doing, very interesting build, keep the pics coming.
Old February 26th, 2007, 10:00 PM   #34
TJontherox
Mall Rated
TJontherox's Avatar
I built the frame like that to put the shocks directly underneath the frame. I wanted the frame to support the entire weight of the rig. I was originally going to tie it into the roll cage but didn't feel that it was strong enough to support the weight of the rig. I am running 2.5" 14 inch travel fox shocks.
Old March 3rd, 2007, 04:06 PM   #35
TJontherox
Mall Rated
TJontherox's Avatar
Finished the tube fenders up and made my front shock hoops today.
pic of the battery bracket on drivers side. I have the same bracket for the other side as well. I have dual Optima yellow tops going in this. With a battery on both sides it should help distribute the weight evenly.
Pic of the cutouts for my shock hoops. I know there are other/simpler ways to do it, but I feel this is stronger than most setups you see.
I sunk the tube halfway into the frame and welded around it. Should be more than strong enough.
Pic of shock mount at the axle end. 5/16" thick shock tabs. Little overkill but it shoudn't bend any. lol
Finished product with the hood down. I will run the typical spreader over top the engine on the hoops as well.
Old March 4th, 2007, 09:03 PM   #36
C.K.
Dont Feed the Cyco
C.K.'s Avatar
lookin good
overkill is never bad either
C.K. is offline   Reply With Quote
Old March 5th, 2007, 10:08 AM   #37
barry1me
Just another day
barry1me's Avatar
Finally now have a chance to work on this a bit. Got a little busy at work and had no room in the shop for me to work after hours. Some plans have changed on it since it was put away and the brought back out. Rear bumper and things like that will change. I started back up by converting to rear disc brakes.
Caliper brackets made out of 5/16 sheet steel.
I know the axle is a little rusty, I may have them blasted along with the frame before paint or powdercoating. Haven't decided on the finish yet, long way off for that.
I used S-10 calipers and CJ front discs with the axle flange turned down to fit in the rotor.
How are you planning on making sure the rear caliper brackets are square to the rotor?
By the way looks great..keep posting pics
barry1me is offline   Reply With Quote
Old March 5th, 2007, 01:17 PM   #38
TJontherox
Mall Rated
TJontherox's Avatar
I bolted the rotor to the axle flange made a fitting to go in the caliper to hook air to it and clamp it on the rotor where I wanted it. I then bolted the plates to the caliper and welded onto the axle tube
Old March 5th, 2007, 01:49 PM   #39
Strangler
Strangler's Avatar
Lower the control-arm mounts on your front axle. You need more seperation. I thought it would be fine and I just had to cut mine off and lower them because the axle was "wrapping" with hard braking and generally felt unstable. I lowered the mounts below axle centerline, and the difference was incredible. Do it now, while its easy.
Old March 5th, 2007, 11:17 PM   #40
TJontherox
Mall Rated
TJontherox's Avatar
Actually the pic is decieving, there are no upper links in there in this pic. That is the drivers side LCA that you see in the pic. I am running the same setup as a couple other people that I wheel with, it has proven itself over time and this is the setup I'm going with. I will keep it in mind though if there seems to be wrapping when finished. Upper arm is 25.5", lower arm is 36.0" with 4" sep at frame end and 9" at axle end. Thanks for the tip.
Page generated in 0.55908 seconds with 83 queries
