TJ/LJ Dana 30 knuckle question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 28th, 2010, 01:18 PM   #1
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Default TJ/LJ Dana 30 knuckle question
Are all TJ/LJ Dana 30 knuckles the same design/casting? I need a set idential to what's on my '05 LJ, and didn't know if there were changes between any of the model years.
Craig
Old September 29th, 2010, 11:06 AM   #2
1x1_Speed_Craig
Simplify...
Anyone?
Bueller? Bueller? Bueller?
Old September 29th, 2010, 11:10 AM   #3
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I haven't checked personally, but Hollander interchange says they are from at least 97-2006.
JohnnyJ is online now   Reply With Quote
Old September 29th, 2010, 11:14 AM   #4
1x1_Speed_Craig
Simplify...
Thanks. I tried car-part.com, but it didn't list knuckles as one of the components to query.
Can anyone else validate?
Old September 29th, 2010, 11:33 AM   #5
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
To the best of my knowledge they are the same. The only thing that changed during those years was the unit bearing and rotor (hat dimension).
Old September 29th, 2010, 11:43 AM   #6
1x1_Speed_Craig
Simplify...
That would definitely be a consideration, then, or are these changes independent of the knuckle design...I guess I need clarification. I want to keep it compatible with the 2005 model year. Do you have any other details, Kevin? Do you have a set at the shop that you'd be willing to sell?
Craig
Old September 29th, 2010, 12:00 PM   #7
Jeeperz Creeperz
GL 4x4 Vendors
Craig
The rotor/bearing combination is independent of the knuckle. You can use any knuckle but you have to use the proper rotor/bearing combination for proper positioning of the rotor within the caliper bracket. In other words, if you use your existing rotors/bearings you'll be fine.
I don't have any knuckles, sorry. I think Ken at All Pro might have some.
Old September 29th, 2010, 12:03 PM   #8
1x1_Speed_Craig
Simplify...
Thanks for the quick reply. Since you don't have any available, I'll post a "Wanted" ad, and may shoot Ken a note, too (I'm not familiar with him or his shop, though).
Thanks again,
Craig
Old September 29th, 2010, 03:59 PM   #9
junk90xj
ALLPRO AUTO
junk90xj's Avatar
Thanks again,
Craig
i dont have any, sorry.
we met only once so i dont doubt you dont remember me. i was with 84scrambler to get a tub from you i believe. ?? maybe it was from someone else though.
http://www.apalansing.com/
Old September 29th, 2010, 04:10 PM   #10
1x1_Speed_Craig
Simplify...
Thanks for the update, Ken. Yeah, I remember, but didn't make the connection (nor remember your name...sorry). Thank you again! I appreciate the response here.
Craig
Old October 6th, 2010, 01:12 PM   #11
1x1_Speed_Craig
Simplify...
Well, I rounded up a set of TJ Dana 30 knuckles semi-locally on the board here (haven't bought them yet, but plan to next Wednesday). My question is this - he had them on a Jeep running 37" tires. Is there anything to worry about in regards to stress on the knuckles given the large tire size? Does anyone have any experience with D30 knuckles failing for any reason?
Thanks,
Craig
Old October 6th, 2010, 01:52 PM   #12
Complete Off Road
Complete Off Road's Avatar
Thanks,
Craig
I have 37s on my TJ with a D30. The passenger side was replaced with the teraflex crossover steering knuckle, and I haven't had a problem with either one. It was like that when i bought the jeep...planning to upgrade axles but just haven't found that bag of $$ yet.
The inner Cs are another story, they have been trussed since they were starting to spread. Or in other words, the knuckle isn't the first thing to worry about.
And while I wheel it, I do so remembering I have a D30 up front. If you want to do hardcore wheeling it might be another story with the knuckle. A guy in our club who runs 38s or 39s had D60 knuckles develop a crack and eventually fail.
And another note about running 37s on a D30, there were 4 TJs on this year's Ultimate Adventure that did so. I bet they had a bunch of spare D30 parts along, but it can be done
Complete Off Road is offline   Reply With Quote
Old October 6th, 2010, 02:51 PM   #13
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
I have never heard of the knuckles failing due to stress. The knuckle issues I've seen ususally involve stripped caliper threads, grooves in the caliper sliding surface, and worn out tapers.
Old October 11th, 2010, 08:43 AM   #14
redleg
Might compare ball joint part numbers and see if they match too. For example, The inner C-s on my XJ axle appear to match the inner C on the WJ, other than the WJ having a couple "nodes" cast at the the upper bend to beef them up slightly, but WJ uses heavier ball joints. Be careful pressing the ball joints out too. The upper C will flex and might get damaged if the ball joint doesn't cooperate. I also compared the inner C to a HP44 I have. The bottom half of the C appears compareable to the 44, but the upper half doesn't come close to the thickness of the 44. I plan to gusset the upper side of my inner C's on my axle build. Hope some of this is helpful for ya.
redleg is offline   Reply With Quote
Old October 11th, 2010, 09:26 AM   #15
1x1_Speed_Craig
Simplify...
Good info, redleg...thanks. I'll compare them within the next couple weeks.
Craig
Tags
tj lj unlmited
Page generated in 1.53538 seconds with 68 queries
