Need Driveshaft for a CJ7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 18th, 2006, 01:16 PM   #1
Marion3
Marion3's Avatar
Default Need Driveshaft for a CJ7
23" from yoke to yoke.... model 20 rear end.
Marion3 is offline   Reply With Quote
Old August 18th, 2006, 11:08 PM   #2
TJrockdogg
Living on the Edge
TJrockdogg's Avatar
have to check measurement, but I do have a CJ shaft. I will let you know tommorrow
TJrockdogg is offline   Reply With Quote
Old August 19th, 2006, 12:12 AM   #3
Marion3
Marion3's Avatar
Awesome, LMK.
Old August 19th, 2006, 08:12 AM   #4
TJrockdogg
Living on the Edge
TJrockdogg's Avatar
well the actual CJ driveshaft is gone but I do have a drive shaft that could possibly work. I'm thinking it's from a YJ, so were on the same page. the drive shaft is 23" - the double cardan joint. the U-joints measures 3.225" across the cross section and 1.06"/diameter at the joint ends. let me know if it will work. if you like I could send a photo of it.
Old August 19th, 2006, 03:00 PM   #5
jeepers48
jeepers48's Avatar
HERES WHAT I HAVE. The good I have a barrel of drive shafts. The bad, Not your size. But .... wait.... theres more!!! I can cut the longer rear drive shaft to your 23" length and weld it to make you a "trail drive shaft".:tonka:
if that will work for you....$20.00
Of course ill try to weld it so its not out of round. "interested"?
jeepers48 is offline   Reply With Quote
Page generated in 0.14167 seconds with 38 queries
