I'm a lazy stinking tigger! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 25th, 2010, 07:08 PM   #1
Nuggets
I fix stuff!
Nuggets's Avatar
Default I'm a lazy stinking tigger!
I'd like to TIG weld some sheet metal on my Honda project. I was thinking of TIG welding the patch pieces in without using (little or any) filler rod. Is this an acceptable pratice? I want to minimize grinding.
Old September 25th, 2010, 07:25 PM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
IMHO, TIG welding sheet metal is for playas.
@clarkstoncracker
Old September 25th, 2010, 07:52 PM   #3
Nuggets
I fix stuff!
Nuggets's Avatar
I've got this monster Airco TIG welder that could weld shit to a rock. I just never use it.
Old September 25th, 2010, 07:53 PM   #4
Nuggets
I fix stuff!
Nuggets's Avatar
You think it might put too much heat in the metal and warp things? I know MIG welding would be quick and dirty. I'm sorta a TIG tard.
Old September 25th, 2010, 08:16 PM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Fock no.
TIG actually heats the surrounding metal less than MIG and you run less risk of warping body panels if you're impatient.
@clarkstoncracker
Old September 25th, 2010, 08:22 PM   #6
skife
skife's Avatar
I think you'd be okay, just make sure there arnt any gaps
Old September 26th, 2010, 07:47 PM   #7
firehawk
Live Action!
firehawk's Avatar
I think without filler you will have alot of holes, unless you are a tig god.
Old September 26th, 2010, 09:04 PM   #8
Nuggets
I fix stuff!
Nuggets's Avatar
I have filler rod but I was looking to keep the bead as small as possible. Also, since the car is a 38 year old Honda, the original sheet metal is almost thin enough to see through it.
Old September 26th, 2010, 09:18 PM   #9
anything old
run it
anything old's Avatar
Your fine running with no rod.......... wait nuggets not wanting to use the rod what the hell?
anything old is offline   Reply With Quote
Old October 11th, 2010, 11:13 PM   #10
Grunto
Grunto's Avatar
Send a message via AIM to Grunto
Only thing is that no filler welding is going to be undercut, even if it is just a teeny tiny weld or tack. Obviously it won't be terribly undercut doing small welds, BUT you might end up grinding more of the surrounding metal off than you'd want. Just use a thin rod to keep it flat.
Grunto is offline   Reply With Quote
Page generated in 0.26206 seconds with 53 queries
