s-10 blazer/tube buggy - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 6th, 2010, 07:41 PM   #41
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
sbcrichie is offline   Reply With Quote
Old October 27th, 2010, 07:34 AM   #42
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
steering update
After talking to lance at psc he thought i burned up the pump because the resi was mounted to low, so i shipped them the pump so they could rebuild it. Then i moved the resi up higher so it is a straight shot down into the pump and added a filter. So i guess we will see how long it lasts this weekend, gonna head to bundy for another test beat on sat.
Old October 27th, 2010, 08:16 AM   #43
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
vehicle specs
started as a 84 s-10 blazer
4' of original frame left under the cab and the rest of the main frame is 1.75x3/16 dom, and the rest is 1.75x.120 wall.
engine: mild 350 with vortec heads and mild cam, quadrajet carb.
turbo 400 trans with ck performance full manual valve body with engine braking, ck performance front pump, ck performance 2nd gear drum thingy mabob, 3000 stall converter, art carr shifter.
borg warner t-case out of a mid 90's chevy truck with a fixed rear yoke.
rear driveshaft with 1410 ujoints, front shaft 1330 cv with flange mount.
rear axle is a lp dana 60 with 4.56 gears, detroit, blue torch diff cover, and disc brakes.
front axle is hp dana 60 with 4.56 gears, spartan locker, gm calipers to fit 15" wheels.
wheels are 15x10 carmen saftey lock bead locks with custom alum outer rings.
37x13x15 boggers
rear suspension is a single triangulated four link with 2.5x16 king coil overs, foa 4x2 air bumps, currently bumped and strapped at 18" wheel travel, should be able to go to 20-24" of travel now with new driveshaft set up just havent had time to mess with it yet. Custom rear sway bar made out of a astro van torsion bar. 8" of compression travel.
front suspension is single triangulated four link with 2.5x16 triple rate king coil overs, foa 4x2 air bumps, bumped and strapped at 14" wheel travel. 6" compression travel.
links: front lower links are 2"x.250 dom, uppers are 1.5"x.250, poly bushings at the frame and 1.250 heims with high mis spacers at the axle.
rear upper links are 1.75"x3/16 dom, lowers are fabricated mostly out of 3/16 plate steel, poly bushings at the frame and 1.250 heims with high mis spacers at the axle.
cooling: howe double pass radiator with lt1 fans and shroud, steering cooler out of a bobcat, big oil cooler and trans cooler with dedicated fans.
20 gal alum custom fuel cell
115" wheel base, 18.5" belly height at ride height on 37" boggers.
warn 9000 winch with master pull rope, not currently working need remote solenoid pack.
3" mandrel y pipe to single 3.5", magnaflow muffler.
psc full hydro steering 2.25 single ended ram, psc pump and pulley, psc orbital.
Old January 2nd, 2011, 09:06 PM   #44
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
started to build the dash finally.
Name:	blazer dash 1.jpg
ID:	72564   Click image for larger version
Name:	blazer dash 2.jpg
ID:	72565   Click image for larger version
Name:	blazer dash 3.jpg
Old January 3rd, 2011, 01:21 PM   #45
02trailblazin
02trailblazin's Avatar
Seen this thing in person a few times. Thing is sick. Can't wait to see the new stuff done to it this summer and to wheel with your group again.
02trailblazin is offline   Reply With Quote
Old January 3rd, 2011, 01:55 PM   #46
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
Very cool rig, unique.
ppkaprince98 is online now   Reply With Quote
Old January 3rd, 2011, 06:43 PM   #47
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Thanks guys. Hey 02trailblazin what do you guys at bundy have planned for this year? Any new obstacles or trails comming?
Old January 3rd, 2011, 07:03 PM   #48
02trailblazin
We got a few new events planned for this year. As far as new obstacles or trails we are aways doing something new. I was actually gonna talk with Mike ( Bundy Owner ) this weekend while we are open to see where we can build some new trails. If you have any ideas on trails or obstacles that would be a lot more harder for your type of rigs let us know.
Old January 3rd, 2011, 07:30 PM   #49
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I think some southern style trails/mild hill climbs with obstacles built in so they would require a little speed and horsepower.
Old January 3rd, 2011, 07:45 PM   #50
02trailblazin
I think we could make something like that happen. I think we have plenty of hills.
Old January 3rd, 2011, 07:49 PM   #51
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Cool im looking forward to the spring! Got any plans for your zj this year?
Old January 3rd, 2011, 08:05 PM   #52
02trailblazin
I just put a set of 35s on it. Gonna put a different set of springs and control arms under it and try to keep it on 4 wheels. Gonna kinda start looking for another zj to build all out. Would like to build a zj on tons and 38s or so.
Old January 3rd, 2011, 08:09 PM   #53
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
cool i thought you might be headed down that road.
Old January 9th, 2011, 08:01 PM   #54
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Got some more done on the dash.
welded up
All sanded and gages wired
Name:	blazer dash welded 1.jpg
ID:	72941   Click image for larger version
Name:	blazer dash welded 2.jpg
ID:	72942   Click image for larger version
Name:	blazer dash welded 3.jpg
ID:	72943   Click image for larger version
Name:	blazer dash sanded 1.jpg
ID:	72944   Click image for larger version
Name:	blazer dash sanded 2.jpg
Name:	blazer dash sanded 3.jpg
Old January 10th, 2011, 04:43 PM   #55
Cbbjeep
Default Electrical tape
What happened to the tape? I was just getting to like it
Cbbjeep is offline   Reply With Quote
Old January 10th, 2011, 06:54 PM   #56
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
i was happy to finally get rid of the tape!
Old January 11th, 2011, 03:53 PM   #57
jkh533
Love the dash!!!!!!!!!!!!!!!!
You got any write ups and pics on the back half work you did?
jkh533 is offline   Reply With Quote
Old January 11th, 2011, 04:50 PM   #58
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I dont have very many pics of the back half, but there are a couple on my dana 60 truss thread in fabrication and body armor.
Old January 11th, 2011, 04:59 PM   #59
89xjr
sommertyme 4x4
89xjr's Avatar
very nice work
89xjr is offline   Reply With Quote
Old January 11th, 2011, 05:03 PM   #60
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
thanks!
Page generated in 0.36306 seconds with 84 queries
