I only have reverse in any gear (manual trans) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 24th, 2010, 01:53 PM   #1
awild
awild's Avatar
Default I only have reverse in any gear (manual trans)
1994 F150 manual trans.
Took the shifter out of the trans because it had a little slop to it. Wanted to see if it was a bushing or something. After I took it out, inspected it, and decided to put it back in, I only have reverse....and the selector is actually in the 2nd gear position. It seems that I can only align it into 2nd gear as there are to pins on the sides of the shifters housing. Even with it "wiggling" in neutral it still is actually in reverse.
WTF did I miss here? btw, I did not do anything to the shifter.
awild is offline   Reply With Quote
Old September 24th, 2010, 02:11 PM   #2
Bones
Bones's Avatar
your shift forks are not installed into the shift rails correctly, or the shifter isn't installed into the shift forks correctly.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 24th, 2010, 02:33 PM   #3
awild
awild's Avatar
Well I think the issue is that I took the dang thing out when it was either in R or 5th. I'll see if I can't somehow monkey this sucker in on an angle to get it to fall into the pins and fall into the R or 5 spot.
Old September 24th, 2010, 02:51 PM   #4
awild
awild's Avatar
What I really need is to know how to shift into neutral without a shifter installed
Old September 24th, 2010, 03:26 PM   #5
4x4klein
Weapon K
4x4klein's Avatar
I just had my '93 apart to replace the shift 1-2 shift fork. It's real easy to tap the synchro sleeves to set them 'in the middle' to free them up from the gears. Also check your shift forks for wear, one of mine was so bad it wouldn't engage the synchro sleeve.
4x4klein is offline   Reply With Quote
Old September 24th, 2010, 03:29 PM   #6
4x4klein
Weapon K
4x4klein's Avatar
If you're interested, I have brand new 1-2 and 3-4 shift forks, new rebuild kit for the shift lever ball, and new metal 'freeze plugs' for the shift rails. I ordered them and didn't use 'em.
Old September 24th, 2010, 03:31 PM   #7
awild
awild's Avatar
All I need is to know how to get the trans into neutral without a shifter. I took it out in either 5th or R (cant remember) and I can't get the angle on it to get it back in that way.
I appreciate the shifter fork advice and possible hook up, but I doubt me removing the "shifter" damaged any internals.
Old September 24th, 2010, 04:12 PM   #8
4x4klein
Weapon K
4x4klein's Avatar
Don't worry about getting the angle correct, just 'reset' the trans to neutral and the shifter to neutral and it'll go right together.
No, you wouldn't have damaged anything, but the reason you took it apart to begin with was because it was loose? Your worn shift forks and shifter pivot is why it's loose.
Old September 24th, 2010, 05:39 PM   #9
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
What he said...
Old September 24th, 2010, 10:38 PM   #10
awild
awild's Avatar
Right....the issue is "how" do I shift it in neutral? I know what needs to be done but I need the directions. Pics help as I have no clue what I'm doing with fords or trans internals
Old September 25th, 2010, 02:19 PM   #11
awild
awild's Avatar
Anyone have a clue? I'm registering on a ford forum right now...
Old September 25th, 2010, 02:55 PM   #12
prozak1986
prozak1986's Avatar
take a picture of the trans with the shifter out of it and post it , my buddy had this same problem with the trans in his ranger and it was a 2 sec fix
prozak1986 is offline   Reply With Quote
Old September 25th, 2010, 03:16 PM   #13
awild
awild's Avatar
Here's one. Had to get good quality in a dim garage and no flash while holding a flashlight. This is looking at sideways.
Old September 27th, 2010, 11:56 PM   #14
Jrod-13
poser wheeler
use a screwdriver to move the shift forks back into place.
Jrod-13 is offline   Reply With Quote
Page generated in 0.32668 seconds with 65 queries
