where did my turn signal go? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 21st, 2010, 09:12 AM   #1
turnofftheradio
Default where did my turn signal go?
1996 F-150
2wd, 4.9, auto, 115,000
So a few days ago my turn signals went out. started flashing fast, then disappeared alltogether. my hazards also went out. I think I have narrowed it down to the hazard switch itself, spraying some contact cleaner through the hazard switch, swearing, and beating on it got them working almost correctly, but they are speeding up again. Is this a common problem? is it a waste of time to take the switch out and clean it, or should I just replace the thing. it is kinda ugly pinkish instead of red after the sun faded it anyways. I really hate when my signals dont work.
turnofftheradio is offline   Reply With Quote
Old September 21st, 2010, 09:13 AM   #2
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
How much is a new switch?
Old September 21st, 2010, 10:01 AM   #3
Bones
Bones's Avatar
I assume you tried replacing the flashing relays? I would be suprised if the turn signal was wired via the hazard switch, but I'm been wrong before...
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 21st, 2010, 11:02 AM   #4
turnofftheradio
havent looked up a price on the switch yet...
turn signals do run through the hazard switch. at least all the other cars I've had. switch has to disconnect the turns to make the flashers work has a set of normally closed and normally open contacts. I'm assuming they are the problem.
I did try swapping flashers to no avail.
Old September 21st, 2010, 06:18 PM   #5
Yota Bill
do you mean all quit working, front and rear, left and right? when flashing fast, did you make sure they were both (on one side) on? Remember, if you lose the front, the rear will flash faster, and vice-versa.
if you did lose all of them, I would assume the switch, and the hazard switch is part of the turn signal switch
http://www.napaonline.com/Search/Det...+50028+2028020
Napa shows it for $64
Old September 22nd, 2010, 07:05 AM   #6
turnofftheradio
yeah, all of them went out. after 1 clean the left side sorta worked, then after a better clean both sides started working.
I think for 65 bucks I'll take it out and attempt to properly clean the contacts. Or I'll wait untill they screw up again since my last cleaning appears to have worked for now...
Page generated in 0.30396 seconds with 41 queries
