93 GMC Jimmy for parts or whole and 90 Dodge cummins 2wd - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vehicle Part Outs
Old September 19th, 2010, 07:21 PM   #1
F350camoford
Default 93 GMC Jimmy for parts or whole and 90 Dodge cummins 2wd
Hi i have a 93 Jimmy with a 4.3 vortec, runs and drives but in rough shape. the 4wd works but the front end is a different gear ratio than the rear, and it needs a transfer case actuator. has decent 31x10.50 tires but front 2 are different tread pattern than the rears. Transmission is not electronicly controled, has had a older 700R4 put in probably out of the early 90's. The dodge is a 2wd and is complete EXCEPT the motor and trans Im doing a cummins swap into a ford. body is not horrible but has the typical michigan rust over the rear wheels and bottom of the doors. pm me or give me a call at 989-553-3772. thanks, Josh
F350camoford is offline   Reply With Quote
Old September 25th, 2010, 01:40 PM   #2
wild thang
how much for the doors?
wild thang is offline   Reply With Quote
Old October 6th, 2010, 01:42 PM   #3
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
How much for the 700R4?
BAD93SBLZR is offline   Reply With Quote
Old October 6th, 2010, 01:54 PM   #4
JohnL
Go until it breaks.
JohnL's Avatar
Send a message via AIM to JohnL
Is the transfer case in the jimmy floor shift or push button ?
JohnL is offline   Reply With Quote
Old November 6th, 2010, 02:48 AM   #5
94jimmyjr
94jimmyjr's Avatar
i offer 300.00 for the blazer.
94jimmyjr is offline   Reply With Quote
Old December 18th, 2011, 11:51 PM   #6
ridejad
interested in cummins parts including, engine, trans, turbo, injectors and radiator please call at 2489782959
ridejad is offline   Reply With Quote
Page generated in 0.26997 seconds with 41 queries
