Starting issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 15th, 2010, 12:15 AM   #1
akojsp
akojsp's Avatar
Default Starting issue
Was having a problem starting my 93 5.8. 99% of time I turn key it would start. Occasionally I would turn key and nothing. Try again. Nothing. Get out, pop hood, shut door, shut hood. Try again, Vrrrrooom. Some time later, it happens again. As I am turning key, son shuts tailgate and suddenly, Vrrrrrrooom. So I go to local electric shop and he nods confidently and says brushes in starter are going bad. So, deciding to replace it in September versus January in Michigan, I buy a rebuilt and replace it. Hopped in truck today and it happened again. Is there something else I should be looking for? Or, is it possible this starter is a POS as well?
akojsp is offline   Reply With Quote
Old September 15th, 2010, 12:23 AM   #2
traveller
traveller's Avatar
Might sound stupid, but have the battery cables been looked at? And have the connections of the cables been check?(both at battery end, stater and ground)
traveller is offline   Reply With Quote
Old September 15th, 2010, 12:57 AM   #3
blownexploder94
Todd
blownexploder94's Avatar
check the solenoid on the fender, its possible cracked, or wires have come loose/ broke wire.
Old September 15th, 2010, 04:39 AM   #4
Yota Bill
intermittant problems are a bitch to find, you need to duplicate the problem and try to find it as it is happening.
By "turn key and nothing." do you mean the starter does not turn/engage, or that nothing comes on at all?
Is anything else going on when it does that? Does the dash light up as normal? Radio or anything else on the truck not work during that time? Exterior lights, brake lights, dome light, any dash lights, blower, any chimes that do come on normally, etc.
Im sure its a loose/coroded contact somewhere, but its almost impossible to guess at where that may be.
Old September 15th, 2010, 09:52 AM   #5
akojsp
akojsp's Avatar
Yes all the lights come on and everything else works. Just no starter. I will check the cellenoid on the firewall as well. But as far as corrosion, when I replaced the starter, the wires were clean and clear. Same for the battery cables at the battery.
Old September 15th, 2010, 05:04 PM   #6
Yota Bill
try to get it to do it, and when it is use a jumper cable to bypass the solenoid...if it cranks then, replace the solenoid
or you could just replace the solenoid and be done with it
Old September 15th, 2010, 09:21 PM   #7
camccardell
tiger blood
camccardell's Avatar
re check your battery to frame and engine cable. I was having a similar problem a few years back, and I would get lights and everything, because the body was grounded.
$10 and a few bolts later, I had a new ground cable hooked up to the engine block directly from the battery and life has been good since.
Asuming your starter is good, and solenoid on the firewall is good, I would look at that.
Old September 21st, 2010, 06:48 PM   #8
akojsp
akojsp's Avatar
OK. It started happening a little more often. I changed the solenoid out. So far, it hasn't happened again.
Page generated in 0.29509 seconds with 47 queries
