Differential Advice - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 10th, 2010, 10:07 PM   #1
redhead_823
redhead_823's Avatar
Default Differential Advice
I'm in the middle of doing SOA on my Scout, and I'd like some opinions on what I should do for my rear differential.
I have dana 44's with trac-lok in the rear and spartan locker in the front.
I've been very happy with the spartan so far.
The trac-lok is completely worn out (no resistance).
Should I?
1. add shims to trac-lok clutches
2. rebuild trac-lok
3. replace trac-lok with open diff for future lunchbox locker
Next question: I currently have 3.54 gears. Should I replace my front axle with one with 4.09 gears and regear the rear to 4.09 open diff (I have all the parts) or stay with the 3.54's?
P.S. I'm a poor college kid with little budget
redhead_823 is offline   Reply With Quote
Old September 20th, 2010, 09:03 PM   #2
wally431
wally431's Avatar
Gears r always good so go to 4.09s. I have LSD in the rear and I hate it I'm either gunna put in an open diff and weld it or get a spool. I'd get an open diff and put a lunchbox in there they are cheap and easy
wally431 is offline   Reply With Quote
Old October 5th, 2010, 10:17 PM   #3
pigfat
GONE COMMANDO
pigfat's Avatar
if its not a DD, you could do mini spool for cheap in the rear and call it a day. You wont be disappointed. If you can afford a gear swap do it but i would do 456 or 488 cuz later you'll want bigger tires and you'll be all set.
pigfat is offline   Reply With Quote
Old October 6th, 2010, 06:33 AM   #4
redhead_823
No spool or welded in this vehicle.
The reason I said 4.09's is because I have access to the gears.
I'm planning on putting an open diff and lunchbox locker in there when I can afford it.
Old October 6th, 2010, 09:13 AM   #5
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Dana 60 rear.
Old October 6th, 2010, 09:28 AM   #6
liv2mx
i like jungle gym's.
liv2mx's Avatar
Originally Posted by Lousypirate View Post
Dana 60 rear.
why? it is no better then what he has. need a 14 bolt or a 70 for a upgrade.
Old October 6th, 2010, 09:31 AM   #7
redhead_823
I'll just steal lousypirate's 14 bolt when he's not looking.
Old October 6th, 2010, 10:15 AM   #8
pigfat
GONE COMMANDO
pigfat's Avatar
mini spool beats lunchbox locker hands down! Mini spool wont break.
Tags
dana 44, differential, limited slip, locker
Page generated in 0.40579 seconds with 47 queries
