Read end help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 10th, 2010, 02:10 PM   #1
Cj7Ed
Default Read end help
I have a 83 toyota , the rear just started leaking outta the pinion , i was just wondering if there is a seal there, or is it the bearing that does the sealing? Also can i just take the 4 bolts off the backing plate and take off the brake lines and just pull the axles, then take out the pig for it to be rebuilt. I called the dealer and they seem to think that you can put a new seal in and not pull the rear end, but how would you set backlash, and check the tooth pattern ?????? thanks!!!
Cj7Ed is offline   Reply With Quote
Old September 10th, 2010, 08:06 PM   #2
ron86toy
R&V Ranger
ron86toy's Avatar
Send a message via Yahoo to ron86toy
correct on pulling the axles...there is a crush sleeve in there...I would buy the solid sleeve before I pulled it apart...I personally would pull the 3rd and check pattern,replace seal and sleeve,check pattern.....alot of good reading here to help you out
http://gearinstalls.com/
ron86toy is offline   Reply With Quote
Old September 10th, 2010, 11:15 PM   #3
Yota Bill
people put way too much thought into replacing pinion seals...the crush sleeve is work hardened by now, nothing will change. Remove the pinion, change the seal, retorque the pinion nut, done. Replaced many, many pinion seals, and never had a single problem.
Old September 12th, 2010, 08:16 AM   #4
Cj7Ed
Yea thats what ive heard from the marlin crawler forum, just pull the nut replace the seal and retighten , call it a day . thanks guys
Page generated in 0.21463 seconds with 35 queries
