need some ideas/help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 9th, 2010, 11:39 AM   #1
jfisch
Default need some ideas/help
i have a dodge 360 motor that i am going to get rebuild and i am going to make a rock crawling truck with it. i do not have a tranny or transfer case yet and i was wondering if any of you guys had any ideas for a good set up??
jfisch is offline   Reply With Quote
Old September 12th, 2010, 09:42 PM   #2
Flat_Black
The Dodge Guy
Flat_Black's Avatar
heres some info for ya
'74-79 RC/TD and '75-79 W-series have the NP203 full-time unit bolted to one of four transmissions.
NP-230 3spd manual, no known interchange with later T-case.
NP-445/4530 4spd manual same as above.
NP-435 4spd manual, output shaft and adapter must be changed to '80-93 to use later NP-205/208/241 T-case, or use later transmission.
A727 3spd auto, output shaft and tailhousing/adapter must be changed to a '80-89 to use later T-case, small blocks can just use a later trans but big blocks must use home built trans to use NP-205/208/241s.
'80-93 Dodge 4X4s have one of six transmissions and one of three T-cases, 205/208/241.
A-727, all T-cases are bolt-ins, 205/208/241.
NP-435, see above.
A-518, 241/205 bolt-up, the 208 does not want to bolt up to the overdrive trans, something about the rear oil seal in the overdrive?
NV-4500, same as above.
G360 Cummins only 29 spline NP-205, no interchange.
Page generated in 0.21872 seconds with 29 queries
