1997 Ford Explorer 4.0 V6 Starting Problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 7th, 2010, 07:55 PM   #1
chevyk10
FORD / GM
chevyk10's Avatar
Default 1997 Ford Explorer 4.0 V6 Starting Problems
My friend has a 1997 Ford Explorer with the 4.0L V6 engine and shes having a lot of trouble trying to start it when its under 20* out. Its in good shape and only has 110k miles, but it cranks really slow when on those cold winter mornings. They battery and starter are for sure both good, and it has the right type of oil in it, so what else would cause it to crank slow as soon as it hits about 20*? It always starts up with no problems during the summer.
chevyk10 is offline   Reply With Quote
Old September 7th, 2010, 09:17 PM   #2
Yota Bill
how do you know the battery and starter are good? has the battery been load tested? has the cranking amp draw been tested?
next check into the cables, but they generally dont cause problems only when cold. That is more often then not a battery problem.
Page generated in 0.14792 seconds with 29 queries
