Speedo bouncing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 7th, 2010, 08:12 AM   #1
akojsp
akojsp's Avatar
Default Speedo bouncing
Just had my 8.8 on my 93 F-150 with a 5.8/e40d regeared to a 4.88 with aussie lockers. My problem is the speedo bounces around at about 45 mph on up. It will jump about 5-10 mph. The speed sensor was replaced, no luck. I recalibrated the speedo for the bigger tires. The speedo is accurate now, but still bounces. Have any of you had this and how do you fix it.
akojsp is offline   Reply With Quote
Old September 7th, 2010, 09:16 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
i had this issue on my old ford, the wires to the speed sensor were all corroded, i think i replaced about 3 feet or so, and the problem went away.
Old September 9th, 2010, 09:52 PM   #3
akojsp
akojsp's Avatar
I'll check that. Where were yours corroded at? We did change the sensor and that did not work.
Old September 10th, 2010, 09:21 AM   #4
fsumotorhead
N8KVB
mine were corroded inside the wire insulation, for about 2.5 feet, i kept stripping some insulation back until the wire looked good and clean.
Old September 10th, 2010, 11:27 AM   #5
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Did the speedo bounce before the gear change? If not, I'd inspect the tone ring on the differential.
Old September 10th, 2010, 11:31 AM   #6
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
Wasn't there an issue with early 90's Ford speedos? My mothers Taurus and a buddies escort both did that above 45. Below they were fine. I remember finding a recall or tsb.
Old September 13th, 2010, 12:00 AM   #7
akojsp
akojsp's Avatar
No it did not. Thanks. I will suggest that to my mechanic.
Old February 11th, 2011, 10:31 PM   #8
akojsp
akojsp's Avatar
Sorry for the late reply here, but tone ring was the correct answer. Thanks!
Old February 12th, 2011, 09:31 AM   #9
Jeeperz Creeperz
GL 4x4 Vendors
Probably got a bent tooth during the gear change.
Happy to help!
Page generated in 0.32198 seconds with 50 queries
