96 Caravan NO SPARK - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 30th, 2010, 02:41 PM   #1
88K5Blazer
Team Misstress Mud Racing
88K5Blazer's Avatar
Default 96 Caravan NO SPARK
As stated im working on a 96 caravan with the 3.3 no spark replaced coil still no spark. I have power to one wire (uper right as the conector is plugged in) while cranking the engine only. How many wires should have power and where do they come from and could something else have gone out to cause this issue thanks.
88K5Blazer is offline   Reply With Quote
Old August 30th, 2010, 06:15 PM   #2
JeepInABox
In too deep
JeepInABox's Avatar
check your injectors for power while cranking, if no power asd is not working probably due to a bad crank sensor
Old September 5th, 2010, 02:51 PM   #3
88K5Blazer
88K5Blazer's Avatar
Ok I installed a new crank sensor but now I have spark but its really weak and it seems that im not getting full power to the coil any ideas. Have aready tried new coil with same results
Page generated in 0.20079 seconds with 32 queries
