dana 70 hd - need info - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 30th, 2010, 03:56 PM   #21
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Originally Posted by blue_toy View Post
Well i went home at lunch and double checked the ring gear number.......the 8 after cleaning the oil off better appears to be a 6, my bad
so my correct numbers on the ring gear:
668 12 0790 Dana D 3 5 307 P8R 25 43 6
So its a 7.17 gear.....i could put some other gear set in as they are available per Randy Ring & Pinion
I also found that it has a 5/8" offset ring gear
I'm told the pinion shares the same shaft diameter as a dana 60 - 1 5/8" weak point
So I have a 70HD, 4" tubes, 7.17 gears, 35 spline 1 1/2" shafts with most likely a Power Lock, I'm told it could also be a Trac lock or True Track posi of sorts
Does 7-28-89 2670i-X on the locker mean anything to anyone other than a date
Thanks for all the input
26701x is the Dana part number for a limited slip case.
The Power-Lok is a split-case 4-pinion limited slip. The Trac-Lok is a 2-pinion one piece design. Looking at the picture, you have a Power-Lok.
Old August 30th, 2010, 04:09 PM   #22
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Yup power lok diff. yes the 60 and 70 use the same size pinion spline/yokes. You have to bump up to a 80 to get a larger pinion stem.
Old August 30th, 2010, 04:36 PM   #23
blue_toy
SLOW IS FAST??
blue_toy's Avatar
Thanks guys..............so with aggresesive driving whats the biggest tire one could expect to hold up.........I know pretty its a open end question.....I run 40's on toyota and am breaking stuff.....only one rear stock so far and twisted Longs....but i kinda baby it.....i want "to beat on" something .....sound familiar Erin
Anyone running this gear set with what tire and good results?
blue_toy is offline   Reply With Quote
Old August 30th, 2010, 06:08 PM   #24
kkodet
kkodet's Avatar
Locker is definately a powerlock, which is not a true locker. But as I said before, the heavier oil you run in it the tighter it will get. I've also heard about people putting an extra disc in these to way tighten them up, but I've never tried that.
If you got 4 inch tubes, you probably do have an HD.
The powerlock that you have will work with all ratios 4.56-7.17. Not to hijack your post, but I've got at least one set of 4.56 gears I'd let go cheap.
Old August 30th, 2010, 11:04 PM   #25
blue_toy
SLOW IS FAST??
blue_toy's Avatar
Well if you had two cheap I'd consider them......i wil keep them in mind...not sure what to do yet....really want to run a 44" or better....
any idea how the powerlock holds up to abuse?
Old August 31st, 2010, 11:02 AM   #26
kkodet
kkodet's Avatar
I've never done any serious wheeling with a powerlock, but from what I hear they hold up well under stockish horsepower. I know some local guys that run them in their big mud trucks with 44 boggers, but they usually only get a season or two before they have to rebuild them. These guys are running 600 horse big blocks though.
Old September 3rd, 2010, 10:46 PM   #27
blue_toy
SLOW IS FAST??
blue_toy's Avatar
Well i've decided to sell these if anyone is interested $550 call 616-886-1869
changing directions
Page generated in 0.22984 seconds with 44 queries
