22re headgasket in 88' - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 27th, 2010, 01:27 AM   #1
Blazin79
Blazin79's Avatar
Default 22re headgasket in 88'
how hard is it to do headgasket on a 22re in my 88 toyota i just got?
Blazin79 is offline   Reply With Quote
Old August 30th, 2010, 05:34 PM   #2
wickedlowss
wickedlowss's Avatar
Default manual
http://personal.utulsa.edu/~nathan-b...sm/engine.html
Factory service manual for the 22re
wickedlowss is offline   Reply With Quote
Old August 30th, 2010, 05:35 PM   #3
wickedlowss
Default headgasket
Are you sure its the head gasket? A lot of times the timing chain has rubbed through the timing cover.
Old August 30th, 2010, 06:14 PM   #4
88 TONKA TOY
Rockin an XJ
88 TONKA TOY's Avatar
Send a message via MSN to 88 TONKA TOY
It's not that hard to do lay the manifold back and you can lay the complete intake back if you are carefull then those are the only gaskets ya need to replace. But like wickedlowss said at least inspect the cover and chain while ya have it apart
88 TONKA TOY is offline   Reply With Quote
Old August 31st, 2010, 03:51 PM   #5
Blazin79
Blazin79's Avatar
yeah headgasket cuz i can see antifreeze in oil and it s burning off when running.i ll be sure to inspect the timing chain for what? how do i know i need new one?
Old September 1st, 2010, 08:22 AM   #6
wickedlowss
Default timing chain
Pull the valve cover and look down at the timing chain , If the chain is sloppy it will usually rub a hole/grooves through the cover and mix coolant and oil. Quite common to confuse this for a bad head gasket on a 22re. I have a good one here u can have if yours is bad.
Here is a crappy pic i found online
http://t1.gstatic.com/images?q=tbn:e.../30cs6.jpg&t=1
Old September 9th, 2010, 08:51 PM   #7
Blazin79
Blazin79's Avatar
great i hope thats my problem i ll check mine then
Old September 14th, 2010, 09:23 PM   #8
wickedlowss
Default ??
Any luck ?
Old September 15th, 2010, 08:09 PM   #9
Blazin79
Blazin79's Avatar
havnet gotten to it but soon i will... i m hoping it s what u said it could be
Old September 25th, 2010, 07:16 PM   #10
Blazin79
Blazin79's Avatar
how long it takes to take off the valvecover and where does the coolant or that hose come in to that valve cover? front or where on the motor i m gonna go take a look... someone wnated to have my truck but i m not too sure
Old September 26th, 2010, 07:38 PM   #11
kickstand
circling the drain
kickstand's Avatar
You need a new one, and guides too, it's a given.
Old October 5th, 2010, 12:25 PM   #12
BOGDOG
BOGDOG's Avatar
Pulled the valve cover off it last night chain appears to be in good shape. One of the PO's may have replaced it and not caught a problem with cover or it is the head gasket. Current owner is supposed to pull head today.
Old October 6th, 2010, 03:07 PM   #13
Blazin79
Blazin79's Avatar
let me know bogdog i m the one who traded with him... i m here to help i even offer his help but our schedule crashes... i m hoping to come n visit his shop one day
Old October 6th, 2010, 08:43 PM   #14
BOGDOG
BOGDOG's Avatar
He was going to pull it yesterday but when I talked to him last night was not done.
Old October 12th, 2010, 12:14 PM   #15
BOGDOG
BOGDOG's Avatar
He had head off last night. Sounds like it was the head gasket.
Old November 17th, 2010, 12:08 PM   #16
BOGDOG
BOGDOG's Avatar
He had the head redone and had all the parts last Sun. Just needs to get off his but & do it.
Old December 23rd, 2010, 09:29 PM   #17
BOGDOG
BOGDOG's Avatar
Ollie must of got it done it is 4 sale on CL. Claims to have new head, he told me he had it redone but that is Ollie for you. Why tell the truth when you are so full of shit!
Page generated in 0.37802 seconds with 74 queries
