205 help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 25th, 2010, 10:59 AM   #1
Default 205 help
I got a 205 from I assume mid to late 70s. I believe my front output to be the cv style. Now I am also running a c6 with the short adapter housing. I can't seem to find a driveshaft that will clear the c6. I have been running just the normal driveshaft on that output but of cousre the ujoint straps are binding the caps and tearing up the needle bearings every trip out. Did they put the cv style front outputs on the c6s or only the manual trans trucks?
Old August 25th, 2010, 11:06 AM   #2
Oh and the front is a 1310 and rear is 1330
Old August 26th, 2010, 07:31 AM   #3
Rear output (trail repair on the one side, broke the nipple that holds the cap).
front output
Old August 26th, 2010, 12:38 PM   #4
thrill20
thrill20's Avatar
I'm 99% sure my bronco had a cv shaft on the front, with a c6. Let me check when I get home tonight. I have a spare shaft from a parts truck too, I can get some dimensions if it would help.
What style 60 are you running in front? 78-79, or later?
thrill20 is offline   Reply With Quote
Old August 26th, 2010, 12:42 PM   #5
My 60 is a 95. I got my tcase ? Answered on pirate.
Old August 31st, 2010, 09:37 AM   #6
bj house
bj house's Avatar
I put a CV front from a Bronco (got it at Jeff's Bronco Graveyard) to help with the angle after I put a 4" lift on my 79' F150 that has a 205. Double cardan joint at the t-case not really a CV. I just had to change the front output flange on the 205.
Old August 31st, 2010, 11:53 AM   #7
But do you have a short or long adapter housing on the c6.
I got 2 different cv shafts from a late 70's and both will hit the corner of my trans and thr pan. I have the short adapter.
Old August 31st, 2010, 12:00 PM   #8
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
doubler problem solved
Old August 31st, 2010, 12:06 PM   #9
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
I like the way he thinks John lol
Old August 31st, 2010, 03:11 PM   #10
I can't afford the way he thinks
Old August 31st, 2010, 03:20 PM   #11
Jeepaholic
Jeepaholic's Avatar
I can't even afford the way I think
Old August 31st, 2010, 08:42 PM   #12
TurdBronco
I ran the short shaft tail housing trans with a 205 in a bronco. I ran a u-joint to u-joint shaft (no double cardan) with the slip yoke on the tcase end. Thats all that would work.
Old August 31st, 2010, 08:44 PM   #13
That's how I have it now.
Old August 31st, 2010, 08:47 PM   #14
bigbchevy
missmrgreenagain
bigbchevy's Avatar
i ran in to the same prob and just went with the cj front shaft to clear
H.o.r.e
Old August 31st, 2010, 08:57 PM   #15
TurdBronco
no shit, guess i should have read the whole thing. Even turning my driveshaft around would make it hit the pan.
I had a 9" suspension lift and no bind in that setup.
To answer your question, late 70's were usually double cardan style.
Old September 2nd, 2010, 08:09 PM   #16
SoupCan
SoupCan's Avatar
u need the longer adapter for the 205, then it will clear, if your using the short adapter, thats the 203 one i think and it puts the front output to close to the tranny
SoupCan is offline   Reply With Quote
Old September 2nd, 2010, 09:14 PM   #17
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Pickups used short shafts and broncos used long shafts, both used 203 or 205s. Why they did that i have no idea. I never had a issue on mine john but mine was the long style. What did you end up doing?
Page generated in 0.29387 seconds with 74 queries
