91 explorer runs rough cold - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 22nd, 2010, 05:45 PM   #1
big_ol_bronco78
Psalm 40:2
big_ol_bronco78's Avatar
Default 91 explorer runs rough cold
I have a 91 explorer with the 4.0, it seems to idle and run rough, has little miss fire, when cold, but after driving a few min, like 5 min, runs fine. Anyone know what this could be, previous owner did plugs and wires and put on new water temp sensor. thank
big_ol_bronco78 is offline   Reply With Quote
Old August 22nd, 2010, 07:15 PM   #2
knightmare_1989
From draggin to muddin
knightmare_1989's Avatar
I had the same issue on a 92 ranger with the 4.0 and it was the air bypass valve on the intake. It wasnt opening all the way when cold, but just enough to not throw a trouble code or light. I have had luck with cleaning them a little and reinstalling just make sure you use a new gasket and not silicone as it can do more damage than help. Just my opinion. Dan
knightmare_1989 is offline   Reply With Quote
Old August 22nd, 2010, 07:42 PM   #3
big_ol_bronco78
Psalm 40:2
i'll give that a shot. thanks
Old August 23rd, 2010, 09:03 PM   #4
big_ol_bronco78
Psalm 40:2
update, cleaned that out, made it idle better, see how it drives tommorrow
Old September 8th, 2010, 06:45 PM   #5
302sploder
302sploder's Avatar
agreed on the IAC valve... made mine idle high this winter... perhaps the MAF too... those are the two i always checked when the 4.0 ran like crap
302sploder is offline   Reply With Quote
Old September 8th, 2010, 10:43 PM   #6
L4CX
Out for the Summer!
L4CX's Avatar
I agree with these guys. Did it to the 96. Both the MAF and the IAC. Just make sure to let them dry well.
L4CX is offline   Reply With Quote
Old September 9th, 2010, 04:20 AM   #7
Yota Bill
carbon in the IAC is a common problem, and cleaning normally solves it. They rarely fail. I consider cleaning that and the throttle body/intake, etc part of a tune up. I have also pulled MANY of them, cleaned them, and put them back on with the same gasket, with no issues at all.
Ford used to make a cleaner that worked extremely well (D9AZ 19579 AA...wow, I still remember the part number after about 10 years...wtf?) but they want to sell parts, so now they make a sticker that says not to clean in side these parts
Page generated in 0.16689 seconds with 44 queries
