1/2 Ton Ford D44 vs. 3/4 Ton Ford D44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 21st, 2010, 10:09 PM   #1
nd4spd71
nd4spd71's Avatar
Default 1/2 Ton Ford D44 vs. 3/4 Ton Ford D44
Can anyone tell me what if anything is interchangable between these axles? Looking at possible picking up a 3/4 ton D44 but know these are not as common as the 1/2 ton ones and am wondering if it is going to be hard to find spare parts for it such as shafts. Any info would be great. Thanks.
nd4spd71 is offline   Reply With Quote
Old August 21st, 2010, 10:29 PM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
The outer shafts, housing, spindles, wheel bearings, ball joints, and differential components are the only things that are interchangeable. The 3/4 ton version uses different knuckles, dual piston calipers, and obviously 8 lug rotors and hubs.
Old August 22nd, 2010, 03:59 AM   #3
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Incorrect, the housing is different and they use different length inner axle shafts. F-250 housing is 3" diameter axle tube where the F-150 uses 2 3/4"
That said they are not that hard to find and plenty of aftermarket parts are available
Page generated in 0.20372 seconds with 32 queries
