np 205 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 21st, 2010, 11:23 AM   #1
electroman4
electroman4's Avatar
Default np 205
Anyone know if a ford np 205 fixed output shaft will fit a chevy 205 case? I need to make this gm case a fixed output shaft. thanks
electroman4 is offline   Reply With Quote
Old August 21st, 2010, 12:08 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
If it's a slip yoke now, it won't fit.
If it's a u-joint yoke (or CV yoke), and the output is 32-spline, it should fit but you'll need a different seal.
Old September 17th, 2010, 11:57 AM   #3
redhead_823
redhead_823's Avatar
lousypirate did this conversion on his chevy 205. He had a parts Ford 205. Had to swap the output shaft and housing, that's it.
redhead_823 is offline   Reply With Quote
Page generated in 0.25587 seconds with 32 queries
