Front Driveshaft too long?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 21st, 2010, 08:12 AM   #1
Torg38
TorgFab
Torg38's Avatar
Exclamation Front Driveshaft too long??
Warning: Jeep newbie, first build.
Swapping the axles in a 90xj, I'm using a non disconnect from a 94ZJ. In full drop. (Completely in the air) The front driveshaft won't bolt up? It looks too long. However at ride height it bolts up. I installed a 4" lift so the axle does have quite a bit of arc but I'm worried that axle will be pushing on the t-case when wheelin.
Has anyone done this swap and had to change shafts?
Is there a change in the ZJ D30 for pinion depth?
Torg38 is offline   Reply With Quote
Old August 21st, 2010, 08:21 AM   #2
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Gotta loveshort-arms!!!! The further the front end drops out, the closer the swing makes it come to the rear.
I had that issue with mine when I 1st started lifting it. I had to take the u-joint caps off and use a pry-bar just to get the driveshat into the yoke. I never noticed any issues with it- no binding, blown-out u-joints, noise, or anything on mine.
Heck- I'm still using the same t-case I originally built for it!
Old August 21st, 2010, 12:12 PM   #3
GREASYHANDS
GREASYHANDS's Avatar
yep just bolt it in on the ground, there should be enough slip left in the shaft. Unless u can do some super flexin u should be okay
GREASYHANDS is online now   Reply With Quote
Old August 21st, 2010, 01:10 PM   #4
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
If you ever find yourself in a situation where the axle is forced down (getting pulled forward through something), you run the chance of cracking your transfer case.
Old August 21st, 2010, 01:34 PM   #5
Mclovin
"The Situation"
Mclovin's Avatar
stretch the wheelbase out.
Old August 22nd, 2010, 03:39 PM   #6
Torg38
TorgFab
Torg38's Avatar
Awsome! Thanks for your help. I'll post some pics after the paint is on.
Page generated in 0.20457 seconds with 41 queries
